can someone tell me standard stair width, standard rise and run also rough opening for a 36″ door..thanks
How to Install Exterior Window TrimRelated Stories
stairs to the basement are normally 36" in the finish around here.
Stair to the upstairs are normally that same 36" plus five inches for a total of 41". That will allow you to have an open rail and still have more than the minimum 36" clear.
I prefer a bit wider stair, 48" max.
a 36" door will require a 38" rough.
blue
thanks blue...good info
Rise and run will be limited by your local building code. A maximum rise of 7 3/4" and a minimum tread of 10", for instance.
The other old rule of thumb I remember is Run + Rise = 17".
-- J.S.
simply put on door opening.......make the opening 1 inch bigger than the door measurement. So say a 32x80 door = 33x81 opening. I learned the hard way a LONG time ago .As for stairs , look at city codes cause they all differ.
A 32" door won't fit a 33" RO. You have 1" of jamb on each side. The RO also must allow for shims.
the rule of thumb taught at the tech school where i took building construction was to add 2 1/2" to both the height and width of the door size. for a 36" door, you need 36" for the door, 3/4" on each side for the jambs, plus 1/2" (+/-) on each side for shims. the r.o for a 3068 door is 38 1/2" x 70 1/2"
That's the rule of thumb I learned from my dad.
But since jambs don't sem to be 3/4" anymore, I shrink the RO down a bit, adding 2" to 2-1/4" to the width.
what kind of doors are you using? all the doors i have hung have a 3/4" jamb. most come from Brosco
I'm talking about interior doors as far as jambs go.
My yard gets prehung doors from Bridgewater Wholesalers, in NJ.
The jambs are 11/16", both clear and FJ primed.
And the doors seem to be not-quite full width. I think they get a little carried away when they put the bevel on. They're 1/16" to 1/8" light.
Hellcat, when was the last time you managed to jab a 32" door, with 3/4" jambs on each side into a 33" opening?
If you can do this on a regular basis, I'd suggest that you audition as a warm up to Houdini.
blue
