I would like to have an “L” shaped concrete driveway poured and stamped in a cobble stone pattern. I have only seen stamped concrete used for patios, which wouldn’t have to handle the same loads as a driveway. Is such a project possible or will the stamped cobble stones break under the weight/pressure of cars entering and turning?
Thanks,
Jason
From durability to energy efficiency, continuous exterior insulation is an accessbile approach to a high-performance wall.
I would like to have an "L" shaped concrete driveway poured and stamped in a cobble stone pattern. I have only seen stamped concrete used for patios, which wouldn't have to handle the same loads as a driveway. Is such a project possible or will the stamped cobble stones break under the weight/pressure of cars entering and turning?
Thanks,
Jason
