standard reveal for pocket door trim?
geoffhazel | Posted in Construction Techniques on December 11, 2006 11:54am
When you cut your trim for the pocket side of a pocket door, how much reveal do you leave between the trim and the door?
  1. TomT226 | Dec 11, 2006 03:03pm | #1
    Don't guress I understand the question.  I trim both sides the same, 1/8" reveal on the split head-jambs, and the split jambs on all casing.
    Or, do you meant the space between the door and the inside of the split jamb?  3/16" in normal if your door isin't warped.
    I modified two I installed in my own home by making the finished opening 1/2" larger than the door. Then I installed a removeable second strike jamb.  If the door ever needs to be removed, I just remove the trim head screws on the strike jamb, one side of the head jamb, and the casing above, and remove the door.  Just have to cut a little caulk which is no problem.
