Standard steel bathtub method?
geoffhazel | Posted in Construction Techniques on October 2, 2002 08:39am
When you install a standard enamelled steel tub with the 1″ lip sticking up around the edge, and you will be installing ceramic tile over 1/2″ cement board, how do you install the cement board?  Do you let it bump the top flange and leave a gap underneath, or shim the board out 1/4″ with lath or something similar, or just let it “bend” over the flange? (my least favorite option).
    JeffBuck | Oct 03, 2002 03:46am | #1
    shim.
    .......Sometimes on the toll road of life.....a handful of change is good.......
    JDRHI | Oct 03, 2002 05:30am | #2
    I shim the entire surround with strips of lath. I then cover framing with 15# roofing felt prior to installation of cement tile backer. Hold tile backer off tub 1/8" so that any possible movement of tub will not affect wall finish. caulk gap with silicone prior to tile installation.
    J. D. Reynolds
    Home Improvements
    "DO IT RIGHT, DO IT ONCE"
    1. geoffhazel | Oct 03, 2002 06:09am | #3
      Yeah, I kinda figured that would be the best way.   Gotta go get me a bundle of lath now.... thanks!
  • xoxo test post 3
  • xoxo test post 2
  • xoxo test post 1
