Steam and tiles
| Posted in Construction Techniques on March 21, 2005 05:08am
I need some feedback on a tile problem. Here’s the background.
We contracted a fancy shower to be installed on a job. The shower is sealed when the door is closed for a steam unit. For the second time the tiles around the steam outlet are falling off. The rest of the walls are fine.
Standard subway tile, 1/8″ grout joint, thinset with latex additive adhesive. It was suggested that the grout joints may need to be sealed with a silicone sealer. My theory is that cementitious products take thrity days to cure to a nominal 100% strength. If the client starts using the steam within a few days of grouting or maybe even a week, it’s enough to penetrate and destroy the grout and thinset.
Would allowing everything to cure for a full thirty days before using the steam allow the wall to withstand the steam?
Scratch your little heads and let’s hear some theories! Thanks.
    RichColumbus | Mar 21, 2005 06:25am | #1
    I'm probably using an epoxy grout in this type of area.  My guess is that the heat and steam combine to break down the grout faster... thus leading to moisture penetrating the thinset.
    I may even be tempted to use an epoxy thinset (the 100% solids stuff).
    Another theory would be that your substrate is reacting to the heat of the steam pipes... and expanding to the point of breaking the tile bond.  If this is the case... I am tempted to insulate in some way the steam pipes (don't have a recomendation... haven't seen the circumstances)... or maybe changing the substrate to accommodate the heat extremes.
    Just a couple of theories...
  2. Bruce | Mar 22, 2005 05:28am | #2
    The tile dude I use always sets shower tile of any kind, ceramic, porcelain, stone, etc. with thinset formulated for marble and granite.  He forewarns me that everything better be ready to get buried under the tile, since removing it means everything is gonna come off down to the bare studs.  There is no separating the tile from whatever substrate you're using, be it wonderboard, mudset or whatever.
    The High Desert Group LLC
    1. tmaxxx | Mar 22, 2005 08:21am | #3
      you would probably get a better response form this site
      http://www.johnbridge.com/vbulletin/forumdisplay.php?forumid=1
      they are the know it alls of the tile world.Tmaxxx
      Urban Workshop Ltd
      Vancouver B.C.
       Now when i nod my head, you hit it.
  3. cmdrvoid | Mar 22, 2005 03:06pm | #4
    Well, alrighty then. Some info to chew on. Thanks for the responses. am checking them out. Thinking this'll get solved. Just glad to have options.
      JDRHI | Mar 22, 2005 04:52pm | #5
      You didn`t mention what type of substrate was used.
      I`m hopin` it were cement backer board and not something less.
      ATTENTION FELLOW BREAKTIME MEMBERS:<!----><!---->
      If you`d like to discuss topics other than home building, come on down to the Woodshed Tavern. Great bunch of guys and gals letting off a little steam about everything and anything. Its not a special club, but.....as of Monday, March 14, the Tavern folder will go behind an access wall. Only those who request access to this folder by contacting [email protected] will be able to view and participate in discussions there.
      1. cmdrvoid | Mar 23, 2005 01:01am | #6
        yup-per...cement backer. my main problem is that it's hard to experiment when the client is already ticked off (being that this is the second time the tile has come loose.)
Eichlers Get an Upgrade
Performance improvements for the prized homes of an influential developer who wanted us all to be able to own one.
