I have a question for the builders out there. A hot tub spec sheet says “bond the slab reinforcement for the tub pad. Huh? Ground it? I learned to never expose concrete steel to earth or sky to inhibit rust.
Framing the floor inside a crawlspace foundation keeps a gable-end addition close to grade.
Ya still gotta' keep the rebar 3" from earth and sky, but ya run an insulated ground wire out to sky, then to electrical ground.
Use a ground rod type clamp to bond the wire to the rebar.
SamT
