Steel Building
Blacky | Posted in General Discussion on November 8, 2004 01:26am
Has anyone here ever constructed a steel building? I was wondering what kind time frame it would take.  Looks simple just never did one and my crane operator is out of town.
any imput would be great…Thanks
Dan
  1. slykarma | Nov 08, 2004 03:18am | #1
    Did a tilt-up slab job back in the spring that had steel columns, beams, roof trusses and decking. 17,000 SF. My crew did footings, floor slab, tilts w/ weld plates, and column anchor bolts. Ironworker subs came in 2 days after the tilt stand and had the whole thing erected in 3 days. They had a semi trailer rig with all the trusses plus a small boom crane on board. Used a rented cherry picker type lift, crew of 3 journeymen and one locally hired labourer. Self contained, impressively fast, decent accuracy.
    Wally
    Lignum est bonum.
    1. brownbagg | Nov 08, 2004 04:01am | #2
      I did this one by myself, took two weeks.after the slab was poured.
      1. slykarma | Nov 08, 2004 05:23am | #3
        Nice one. Is that your own shop?Lignum est bonum.
        1. jeffwoodwork | Nov 09, 2004 01:50am | #4
          The metal frame itself isn't too bad with a cherrypicker or small lift once you have the slab poured and your anchor bolts set.  What takes time by yourself is all that insulation and screwing the sheeting to the walls, ditto for the roof.
  2. richardsmyth | Sep 05, 2014 06:36am | #5
    It typically take less time to construct a steel building than other building types. This is because metal building systems components are designed and pre-built which are then easy to assemble. Thus small buildings can be constructed in 2-3 days and larger one can hardly take a month. We recently have our building built by worthless spam link removed in 2 weeks.
      MarkH | Sep 06, 2014 07:02am | #6
      Steel buildings colorado springs lawsuit
      I heard they are in trouble for using weak bolts and some of their buildings are dangerously substandard.
Putting Drywall Sanders to the Test: Power, Precision, and Dust Control
A pro painter evaluates a variety of drywall sanders and dust collection systems for quality of finish, user fatigue, and more.
