Bath tubs. What do people like? Steel, Cast Iron, or FG. I see alot of FG tubs. is this because for spec houses they are cheap?
A Modern California Home Wrapped in Rockwool Insulation for Energy Efficiency and Fire ResistanceRelated Stories
my preference..
1- cast iron, 2- composite, 3- steel.
I see mostly composite tubs go in maybe some of it is because they come in more "stylish" patterns and colors.
Why?
Why cast iron first and steel last?
stand in both and decide...
I believe the finish is much thicker on cast over steel for one thing. Look at the margins of both, the steel finish looks like paint overspray while the cast looks like bonafide baked enamel.
In 2010 I was studying how to replace my old failed finish cast iron tub. Times were lean and the $100 steel tub was looking pretty good. Enter an historic tornado a couple miles away during which I resided in the old 350# tub. Next day among other assorted debris deposited on my property was a steel tub. The front skirt was bent up at a 90* angle to original and it had a couple dents in it sorta like bullet marks. Also about a quart of muddy water.
I don't offer this as any reason to buy a cast iron tub over a 40# steel one but it pushed me over the fence for the cast iron one...
Yeah, it would probably be possible to make a substantial steel tub, such that you didn't feel like you were sitting in a tin can, but it's not commonly done, probably because cast iron is as cheap and light as a well-made steel tub would be.
A tornado can put your truck up in a tree. A couple hundred pounds doesn't mean squat....but if it makes you feel better just before you get sucked up into the air then that's something.
