Steel window frames sweating
Jercarp | Posted in General Discussion on November 19, 2009 06:12am
Forty one stories up in newly renovated apt., all very high end. Windows, starting 3′ off floor to top of ceiling, (9′ & 10′). are all the way around the outer walls of the apt. with walls facing east & south. The finished steel frames are sweating bad enough to run onto the expensive wall coverings below. The sills are steel as well. Sometimes the sun is very intense, other times it’s c-c-c-cold up there. Climate control is throughout the apt, but they still sweat.
Designer wants to wrap all of this in wood.
I’m up in the air (literally) about it. If I glued wood to the frames and they were painted or finished & sealed, would this not stop them from sweating? I would be stopping the condensed air, no?
Don’t want wood rot above Philadelphia here.
Solutions?
  1. DanH | Nov 19, 2009 03:11pm | #1
    Damned if you do, damned if you don't. There WILL be condensation behind the wood, if you install it. But if you seal around the edges of the wood well enough there won't be as much condensation as now.
    But in Philly it doesn't get that cold for that long, so the arrangement might have time to "recover" between episodes.
    Of course the other thing to do is to check the humidity in the place. It may be high -- shouldn't be above about 40%, and lower in the coldest weather.
    A strong nation, like a strong person, can afford to be gentle, firm, thoughtful, and restrained. It can afford to extend a helping hand to others. It's a weak nation, like a weak person, that must behave with bluster and boasting and rashness and other signs of insecurity. --Jimmy Carter
    1. Jercarp | Nov 19, 2009 03:23pm | #2
      "Damned if you do, damned if you don't."That's exactly what I'm afraid of. Thanks for the reply.
      1. calvin | Nov 19, 2009 06:05pm | #3
        What about using pvc (azek or similar).  Relative same workability and no absorption of the probable moisture.A Great Place for Information, Comraderie, and a Sucker Punch.
        http://www.quittintime.com/
  2. calvin | Nov 19, 2009 06:07pm | #4
    Thin foambd first, then wood rap?
    But, I'm assuming glazing set from the inside?  Need to be able to reaccess later.
    or do they set glazing from the ext. that far up?
    popawheelie | Nov 19, 2009 07:30pm | #5
    Isn't one reason for using steel frames so they are thin and the glass is maximized?
    My first house had steel windows in So Cal. Nice veiw out of them.
    The way the steel is so skinny it really opens the window up.
    If you wrap the windows that look will be changed.
    "There are three kinds of men: The one that learns by reading, the few who learn by observation and the rest of them have to pee on the electric fence for themselves."
    Will Rogers
    1. brownbagg | Nov 19, 2009 07:49pm | #6
      They are not sweating due to metal but because there is too much moisture in the air
      1. Jercarp | Nov 20, 2009 05:47am | #7
        Yeah, I think you're right.
        Steel is a better conductor of temperatures and also when the sun comes in on that south & east exposure, there is heat built up just inside of where the windows are, but the steel frames will stay cold, therefore there will be condensation on those frames pretty much guaranteed. My thought is to thermally seal the frames with a material that is non-conductive and water tight.The design of how it's going to look is not up to me.
