Stepped footings for ICF foundations
If you have built into a hillside with an ICF foundation, and stepped your footings, did you ease down in 16″ drops, or just take one big step?
Our lot has a gentle fall, maybe 7 feet in 50 feet, and we want a total of 4 feet of footing drop from high to low, over a footprint length of 36 feet.
One big step is simpler to excavate, but costs more in ICF materials (which are very pricey) and concrete.
The engineer in me likes three steps of 16 spaced 8 feet or 12 feet, but my partner thinks it is too tedious to do multiples.
Do the multiple steps. It's easier and cheaper (by the time you're done) and a real lot stronger.
If you sketch the site and then sketch the ICF blocks you'll see what I mean. That one big step gets expensive.
easier to do multiple sixteen inch steps
Gene, this might sound counter-intuitive (or just dumb), but I formed and poured a concrete wall on top of my stepped down footers to bring it all up to one level before I started with the ICFs. (and ICFs like a very level, smooth footer) This was for a walk-out basement, and all the bare concrete is below grade.
I was just too cheap to spring for the extra ICFs when they wouldn't have improved things any, except perhape being more convenient to use. This was my house, and staying within budget was a high priority.
Our plan is to use the Logix ICF block with 6" core, and the block has an overall thickness of 11 3/4".
That being the case, how thick would I make the walls for the ICF to sit upon?
I had thought about this, and am now rethinking it, but the issue of wall thickness is still a question.
Gene - you may be past this now, somehow I missed your reply - I made my buried walls 12" wide. Having the level (both axis) footers makes ICFs go much faster & straighter.
Treat every person you meet like you will know them the rest of your life - you just might!
