Sticky tiles
| Posted in General Discussion on March 12, 2003 08:02am
I installed Armstrong urethane tiles on my kitchen floor a couple of years ago.  I have several joints where dirt accumulates, some in traffic areas and some where there is no traffic at all.  At these joints there seems to be a sticky substance on the surface of the tiles that captures dirt.  I use Goo Gone to remove the substance and the dirt but at these joints it always seems to reappear.   What is weird is that only a portion of a joint line is affected (about 3-4 inches) and adjacent tile joints do not have this problem.  I would appreciate any ideas you may have about what the cause and cure of this problem might be.  Thanks!
  1. andybuildz | Mar 13, 2003 02:07am | #1
    I'd call Armstrongs tech #
    a
    "As long as you have certain desires about how it ought to be you can't see how it is."
  2. calvin | Mar 13, 2003 04:24am | #2
    Floor adhesive is coming up.
    __________________________________________
    http://www.quittintime.com/
    1. locobis | Mar 13, 2003 11:28pm | #3
      Would the adhesive come up even though the floor has been down since 8/00?
      1. calvin | Mar 14, 2003 02:58am | #4
        Oddly enough, yes it could.  Would be even more pronounced in the heating season, just above an area that ductwork runs under, or maybe in the draft area of a register.  Am thinking maybe the wrong knotched trowel was used, leaving too much adhesive to start off with.  Best of luck.
        Edited 3/13/2003 8:27:39 PM ET by calvin
A New Approach to Foundations
