Sticky weatherstripping
MikeR | Posted in General Discussion on August 2, 2004 02:30am
All,
Any known cures for sticky weatherstripping?  We installed new vinyl weatherstripping in the jamb kerf of a painted wooden door and a new rubber bumber seal in the aluminum threshhold and the rubber piece in the threshhold sticks to the door each time its closes.
By stick, I mean bad enough to pull the paint a little!  I tried a spray silicone then Armor All and a host of other items to no avail.  Next item is something like baby powder.
Any other thoughts?
Funny thing is same door does not stick to the vinyl stripping…
Mike
  1. FastEddie1 | Aug 02, 2004 03:30pm | #1
    Rub the mating surface of the door with a piece of parafin wax.  A bar of soap also works.
    Whenever you are asked if you can do a job, tell'em "Certainly, I can!"  Then get busy and find out how to do it.  T. Roosevelt
    RichColumbus | Aug 02, 2004 04:23pm | #2
    Whatever you do, don't use anything with an alcohol base, even to clean it..  It will condition the rubber and make the situation even worse.
    Wax should do the trick.  I use car wax...  along the same theory as paraffin.
    1. MikeR | Aug 04, 2004 04:13am | #3
      Ed and Rich,
      Thanks guys!  That worked like a charm!
      Gosh, I love this forum.  Helped me build my house, now helping me maintain it!
      Mike
