Still possible to buy 1/4 in. rebar?
OldHouseRestorer | Posted in General Discussion on May 6, 2010 09:45am
Is it still possible to buy 1/4 in. rebar?  So far I have been unable to find anyone in the Kansas City – Topeka area who still carries it.  From what I can find out on Google, it’s still being made.  I’m going to be installing some drainage which involves minor concrete work, and bending the 1/4 in. rebar is a lot easier than working with the larger sizes.  The local Ace hardware has some “electric fence posts” which are constructed of a 4-ft. length of 1/4 in. rebar, coated, and with a flat metal piece attached.  Trying to find a seller of 1/4 in. rebar in the area by using Google has produced no usable results.
  1. Clewless1 | May 08, 2010 11:09am | #1
    I'm in SoCal ... out in the sticks and I think I saw some being used for a two layer block wall around a landscape area just the other day. I was a bit surprised at the small dia.
  2. davidmeiland | May 08, 2010 11:34am | #2
    Could you not use
    3/8" rebar? It's very easy to bend and if your concrete has any thickness at all then it should be easy to get 3/8" in there.
    If all you need are very small quantities then you could consider all-thread, I guess.
