stone ledge?
| Posted in Construction Techniques on April 7, 2003 08:47am
I usually have a concrete ledge for stone/brick.
This job has none. I’m thinking of digging down 3 and a half feet and pouring
a 4″ ledge up to grade.
The other option is stell angle, how long does steel last before it rusts and weakens?
  1. RussellAssoc | Apr 07, 2003 09:48pm | #1
       We brick or stone on many renovations with no brick ledge.  3 1/2" heavy angle iron drilled about 16" on center, placed about 6" up from grade for the ledge.  Stainless bolts (redheads) into the foundation.  You'd have to be a very young man for it not to out live ya.
       As with anything structural have an architect or structural engineer size it.  It'll take 5 min, but probably cost $200.  Still very cheap insurance.
  2. timkline | Apr 08, 2003 02:18am | #2
    If you should choose to excavate and the house has a full basement, you must (should) go to existing footer. Other wise you risk resting your new footer on backfilled material.
    carpenter in transition
    1. UncleDunc | Apr 08, 2003 11:35am | #3
      Or the new pour can be keyed to the existing concrete walls with rebar dowels. If there is not a solid mechanical bond between the old and new concrete, I agree with you, the new concrete should rest on the footing.
      1. timkline | Apr 08, 2003 04:42pm | #4
        Would you really do this ?  Go through the expense of putting a new brick veneer on a home and hang it off of rebar ? I don't think I would take the chance. I'm not even that thrilled about the idea of bolting the angle on the wall as previously mentioned, but I know our mason does it occasionally when he has no other option.
  3. RussellAssoc | Apr 08, 2003 08:12pm | #5
       Once again, the angle iron solution is widely used in renovation work, proven over years of experience, and in comparison to adding a concrete brick ledge, exponentially more cost effective.  Just have it size by a professional.
    1. WendellGee | Apr 10, 2003 07:48am | #6
      Thanks all for your tips.
      I'm now considering using a man-made stone which would
      not require a ledge.
      Anyone know anything about "Dutch Quality Stone" out of Ohio? Their
      brochure has one that looks like the stone that was selected for the job.
        Mongo | Apr 10, 2003 12:08pm | #7
        Wendall,
        Cultured Stone has the best reputation and the most recommendations as the top man-made faux stone product from those that hang here at FHB.
        It's from Owens Corning, and thus should be available in your area.
        http://www.culturedstone.com/
