I added on to my house with a 16 x 32 room. This room has a porch built all the way around it with a roof over the porch. I installed can lights in the ceiling of this room. The ceiling follows the 2 x 12 rafters to give it a vaulted effect. The problem is that I get a very bad draft down through the lights because of them being just off the porch. At the present I do not have trim rings on the lights because the ceiling isn’t complete. What can I do to stop the draft?
![](https://images.finehomebuilding.com/app/uploads/2024/04/10100343/01232346-chimney-cricket-hdr-1-thumb-16x9.jpg)
Easy-to-make tools simplify the framing, while time-tested flashing techniques make it last a lifetime.
James, look here for a start, it's about 10 lines down from your post.
< Obsolete Link > Jim Tredeau "Any ideas for insulating around canister lights?" 1/4/01 2:45pm
I added on to my house with a 16 x 32 room. This room has a porch built all the way around it with a roof over the porch. I installed can lights in the ceiling of this room. The ceiling follows the 2 x 12 rafters to give it a vaulted effect. The problem is that I get a very bad draft down through the lights because of them being just off the porch. At the present I do not have trim rings on the lights because the ceiling isn't complete. What can I do to stop the draft?
