Hello eyeryone, I have a question. Is it okay to store power tools in an outdoor unheated garage or shed? I think the windings of the electric motors will rust. I don’t used some of them very often so they would sit there for months on end. Thanks
![](https://images.finehomebuilding.com/app/uploads/2024/05/23122928/01232448-bracing-for-storm-thumb-16x9.jpg)
Insurance industry research shows that stout roofs, strong windows, and metal connectors can help protect houses from high wind, hail, and hurricanes.
Will storing your tools in a Low Humidity environment keep them from developing rust on the steel part and is just a generally good idea all around the windings on an electric motor are copper and often epoxy coated copper so that's not really going to be the problem.
Heat is bad for the rubber and plastic parts, and for lubricants. Cold is only a problem if it causes condensation, which will bring rust and corrosion with it.
-- J.S.
I have worked fairly cold climates 3/4 of my life and never had a heated place for tools. Never saw any problem from that.
I store my tools in the back of my truck and have never had any problem with any of them because it wasnt heated.
