Storm Cellar Door finish
WE | Posted in General Discussion on June 25, 2012 08:23am
I’ve built a storm cellar door and would like to put a very long term, yet attractive, finish on it.  Due to the relatively flat slope, I initially planned to fiberglas it, so when it was installed 6 months ago I coated the Advantech with resin, planning to finish the job ‘later’.  I also stapled 4 mil plastic over it.  Now the plastic has UV degraded and I recently removed it and ‘later’ has arrived and I need to finish the job.  However, I’m having second thoughts about the fiberglas; both the necessity and because of the amount of work.
Any thoughts about that long term durable finish?  Am I way over-thinking this and should simply use good quality paint and plan to repaint as needed?   If so, what paint is ‘the best’.
Thanks guys
Walt
    xxPaulCPxx | Jun 25, 2012 11:49am | #1
    Well, you're probably not off to a good start by leaving the work out in the elements for months BEFORE you paint it.
    What about applying a rolled roofing product instead?
