Stove Exhaust fan and duct size
looking to install a stove exhaust fan unit that moves 300cfm at high speed.
Duct size for fan is 7″- existing ducting in house to outside is 6″
I know that it is not ideal, but will it work if I reduce down to 6″ from the 7″ or am I just asking for headaches?
Thanks.
Steve
It'll work -- a little less perfectly than with the right size duct, but it'll work. I suppose it could be a code issue, but probably not.
My experience with reducing a range hood duct below the recommended size was not a happy one. Like Dan says, it will work, and it probably won't violate any code rules.
But you may get all kinds of pulsating noise when the fan is on high speed and can't exhaust air the way it was designed to. If you're doing this job for a client I'd get it signed off with the reduced size so you don't get called back at your expense.
In my case I was the contractor and owner, but I still tore it out and started again. After doing it right I'm much happier, and so is the fan.
Scott.
thanks Scott
that's what I needed to hear.
I did it. If the run is short and not many elbows, it is not a problem. Resistance to air flow is related to length of pipe but mostly elbows. Clean old duct well.
how long is long?- this is a clean (one elbow) run (in actic) of 16 feet
existing duct has never been used.
thanks
Whatever you do ... seal the duct (no duct tape!!) and insulate it so the contents don't condense inside the duct ... over the years this can become a big fire hazard.
>>>seal the duct (no duct tape!!)Why no duct tape? (Or do you mean the cloth stuff?) I think the foil-type duct tape would be OK.
Foil type should work. But remember to install the sections "backwards", with the narrow end pointing down so that the grease doesn't run through the seams and destroy the adhesive.
A strong nation, like a strong person, can afford to be gentle, firm, thoughtful, and restrained. It can afford to extend a helping hand to others. It's a weak nation, like a weak person, that must behave with bluster and boasting and rashness and other signs of insecurity. --Jimmy Carter
Right, no grey/cloth duct tape. Use foil tape or duct mastic sealant. Duct tape good for everything but ducts.
A bit of trivia: It's actually "duck tape", being originally invented as a utility tape made out of "duck" fabric. The name got corrupted into "duct tape", even though it never was intended for ducts.
Re trivia: True or not--I like it.
http://en.wikipedia.org/wiki/Duct_tape
Ain't that just really interesting ... really it is!! Nice piece of trivia. And duct tape has gone to the moon and back! wow!!
It is important to pick the right duck for the job.;-)
Viaduct?View Image
Do not run duct backwards, it will create turbulence not good for air flow. Roof cap is a consideration. Typical " T " types restrict air flow. China cap with a cone diverter on bottom works great , but only available at sheet metal shop usually. Put ascreen on it. Go with duct size required.
wookie
