straightening a wall
CaptainMayhem | Posted in Tools for Home Building on January 1, 2009 10:43am
I worked for this framing crew a few years back and as we stood walls instead of bracing them up with 2xs they’d use turnbuckles..I think that’s the name for them…They use em in form work all the time..Anyhow, it was real slick cause when you went to straighten said wall all it took was a turn of a wrench as opposed to a bow and arrow or some other janky method…anyone else out there ever use these…I found some in the next town over but they were a bit pricey…I’m thinking about making a bunch somehow out of different sampson hangers..
All I ever wanted in life was an unfair advantage…
    jonblakemore | Jan 01, 2009 10:59pm | #1
    These may be what you remember seeing:View ImageMike Smith made his own- you can see them here:View Image
    Jon Blakemore
    1. mikeroop | Jan 01, 2009 11:14pm | #2
      John how did you make the word these a link?
        jonblakemore | Jan 01, 2009 11:34pm | #6
        Here is what my HTML version looks like:<a href=http://www.proctorp.com/wallproducts/img/prod_4a.jpg>These</a> may be what you remember seeing:<p>
        <img src="http://www.proctorp.com/wallproducts/img/prod_4a.jpg&quot; ><p>Mike Smith made his own- you can see them here:<p>
        <img src=http://forums.taunton.com/n/docs/docDownload.aspx?guid=2D886FCF-FE53-414B-B73B-BA2E78E1B62F&webtag=tp-breaktime><P>So, to make "these" a link, all you would do is type <a href=web address you want to link to here>These</a>. It's not really much more work than copying and pasting a link.If you go to this link:http://forums.taunton.com/n/mb/message.asp?webtag=tp-breaktime&msg=86247.38&search=yYou will find a tutorial at that link. To be fair, I must say that I'm pretty sure Luka was the one who wrote that, I just copied and pasted.
      2. rasconc | Jan 03, 2009 02:44am | #41
        Load:
         TinyURL.com
        Then you can name it what you want.  Thnks to Pif who turned me on to it after seeing it here for a while.For those who have fought for it Freedom has a flavor the protected will never know.
      hubcap | Jan 01, 2009 11:29pm | #4
      I have four of them-  cost around 25 bucks each
      like the catalog pics
      they are great- one guy can straighten a wall no problem
      I am getting some made up like Mike's because they can be lengthened for taller walls.
      mine are only practical for up to about 12' wall height.No Tag
    3. Riversong | Jan 01, 2009 11:34pm | #7
      Problem with Mikes' homemade version is that in this picture he's pushing/pulling on the studs instead of the top plate.
      Riversong HouseWright
      Design *  * Build *  * Renovate *  * ConsultSolar & Super-Insulated Healthy Homes
        jonblakemore | Jan 01, 2009 11:51pm | #8
        Aren't the studs connected to the plate?I don't see the issue. You stand the wall, string & brace, install joists/rafters/trusses, pop braces loose. Where's the plate going to go?
        1. Riversong | Jan 02, 2009 12:26am | #9
          The idea of wall bracing (besides just keeping it from falling over) is to straighten the top plate before nailing off floor or ceiling joists. That's what springboards are for.  Commercial wall screws, like in the first picture, are always attached to the top plate for fine-tuning.
          Edited 1/1/2009 4:26 pm ET by Riversong
            jonblakemore | Jan 02, 2009 12:39am | #10
            I understand that, but as the stud goes, so goes the plate.I don't understand why a brace attached to a stud which is solidly attached to the plates cannot move the plates.
          2. Riversong | Jan 02, 2009 01:06am | #11
            Define "solidly attached". Most framers shoot two 0.131" gun nails into the endgrain of each stud. The double top plate is usually in place before stringing and straightening, as that will effect the alignment of the wall.
            You excert any force on a single stud (particularly without full sheathing in place, as in the picture) and it's far more likely to shift on the plate than to straighten out a double plate.
            You will not find a commercial wall-straightening jack that is not intended to be tied to the top plates. This is standard (and correct) industry practice.
            Edited 1/1/2009 5:07 pm ET by Riversong
          3. frammer52 | Jan 02, 2009 02:16am | #12
            Bob, I don't know about Mike but we always toenailed the studs we attach the braces to.
          4. Riversong | Jan 02, 2009 06:28am | #19
            Who the hell is Bob?
            So you decide in advance which of the studs will get braced and toe-nail those?
            Or you toe-nail them upside down once the wall is standing?
          5. frammer52 | Jan 02, 2009 03:18pm | #24
            sorry Robert.
            Upside down?
            Yes we nail after the wall is standing as we straighten with a gun in one hand and 2x4 in the other.
            jonblakemore | Jan 02, 2009 03:04am | #13
            Look, I think the commercial wall braces are great. I've used them before and they're nice.Still, I've straightened many walls with a brace fastened to the stud and not the plate. If you use good plate material, you shouldn't have to exert a tremendous amount of force on it.<!---->
            *edited for spelling
            Jon Blakemore RappahannockINC.com Fredericksburg, VA<!---->
            Edited 1/1/2009 7:10 pm ET by JonBlakemore
          7. Snort | Jan 02, 2009 03:15am | #14
            Since you seem to be such a sematic stickler... the problem you actually have with Mike's apparatus is in it's placement, not the the actual apparatus, course maybe your real problem is with Mike... but I guarantee you Mike's placement will straighten out the top plate with very little effort, and no damage.... I know, I know, if you really believe it, you can't be wrong.http://www.tvwsolar.com
            Now you see this one-eyed midget
            Shouting the word "NOW"
            And you say, "For what reason?"
            And he says, "How?"
            And you say, "What does this mean?"
            And he screams back, "You're a cow
            Give me some milk
            Or else go home"
          8. Framer | Jan 02, 2009 04:54am | #18
            I toenail studs top and bottom. The braces get nailed to the top of the stud just under the top plate.Double top plate is always on before the walls are lifted the way we frame.
            That might be true nailing the way you said, but it's not true toenailing. Studs don't move when pulling/pushing a brace.
            Maybe that's the standard and correct way with wall jacks, but it's doesn't have to be done nailing braces into the side of toenailed studs.
            Joe Carola
            Edited 1/1/2009 8:56 pm ET by Framer
      2. MikeSmith | Jan 02, 2009 04:03am | #15
        actually.... in that pic i wasn't straightening.... just temporary wind bracing
        before we set joists, we'll double the plate, and string and block .... a wall like that will probably get two adjuster braces...probably nailed to the stud , sometimes to a plate
        the braces will stay in place until the subfloor is glued and nailed
        we started out using spring braces , like everyone else......
        but i saw these at a concrete equp. supply house back in 2001....  just  tack nail them to any piece of wood
        you can also drive a rebar stake thru them  if you are working over gravel instead of flooring
        when you strip , all you have to transport and store is a 2' piece of hardware
        here, we're using one to  brace the  beam  in a plumb  position
        Edited 1/1/2009 8:05 pm ET by MikeSmith
        Edited 1/1/2009 8:07 pm ET by MikeSmith
        1. Marson | Jan 02, 2009 04:35am | #16
          We call 'em "turnbuckles" which probably isn't the proper name. Funny, but we always nail them to a stud or top plate, and have the other end fastened to a stake or a block on the floor or whatever. I can't tell you why that is. I guess one guy can easily string a wall, though usually there are a few involved.
        JeffBuck | Jan 03, 2009 11:28am | #48
        I'd just like to add that I also think Mike is 100% wrong all the time, even when I know he's right.
        so I think you are 100% right, even when you are totally wrong.
        damn that Mike Smith!
        I say it's his fault that you are wrong so often ...
        fancy turnbuckle guy ... why I oughta ....
        what with his wall straightening and such!
        one day Smith ... one day ... you'll see ...
        Jeff    Buck Construction
         Artistry In Carpentry
             Pittsburgh Pa
        1. MikeSmith | Jan 03, 2009 05:05pm | #49
          hah... i put the stamp on your letter upside down , didn't i ?it's always the little things that get under your skinMike Hussein Smith Rhode Island : Design / Build / Repair / Restore
            JeffBuck | Jan 04, 2009 08:31am | #51
            hey ...
            Cath just told me yesterday that yer gonna have another baby in the family!
            (her, being the "reader" in the family ... I just look at the pictures)
            I said ... Wow ... didn't even know Mike had any egg's left!
            Congrats!
            and oh yeah ... thanks for the added bonus.
            Cath will enjoy a nice nite out where I have to sit quietly.
                 Pittsburgh Pa
          2. MikeSmith | Jan 04, 2009 06:54pm | #52
            r we talkin about  Finn ?  ( ne  6/26/08 )
            here he is with the blood money........
            if you go to       ##say hello to Phalen ##  , you can see some more ...
            Edited 1/4/2009 10:56 am ET by MikeSmith
      CaptainMayhem | Jan 02, 2009 08:42am | #21
      no...that's not what they were..similar principal thoughAll I ever wanted in life was an unfair advantage...
  2. Notchman | Jan 01, 2009 11:28pm | #3
    I've used them for years: They're called foundation wall jacks, but can be used in a lot of applications.
    I bought 20 new ones three years ago from Masonry Supply in Portland, Oregon for $10 each, brand new in the box, made in USA. I challenge you to fabricate them for that!
    Masonry Supply is actually a nationwide firm that sells and rents masonry tools and equip. Do a search.
    Sometimes, rental yards will sell them used for even less.
    1. brownbagg | Jan 01, 2009 11:30pm | #5
      i got about 50 of them laying in my back yard
      CaptainMayhem | Jan 02, 2009 08:40am | #20
      Wow....that's cheap...I was quoted 75 each for 4 footers...but I'm up in alaska now...I got my roots in P-town though...hows work out there nowadays? it was quite scarce and low paying when I left`in 2004All I ever wanted in life was an unfair advantage...
    3. MikeSmith | Jan 02, 2009 04:33pm | #26
      those are probably the same ones i bought...
      Capn Mayham made me blink ...
      do they really call portland .....P'town ?there is only one P'town as far as i kow....... and it ain't on the left coastMike Hussein Smith Rhode Island : Design / Build / Repair / Restore
      1. marv | Jan 02, 2009 04:54pm | #27
        I use the Ellis wall brace.  At $14 each, they're a bargain.  The screw is much coarser than a regular thread so you don't have to make as many turns as you would with a home made brace.  http://www.Ellisok.comYou get out of life what you put into it......minus taxes.
        Marv
        1. MikeSmith | Jan 02, 2009 07:56pm | #28
          that's the one i  use
          View ImageMike Hussein Smith Rhode Island : Design / Build / Repair / Restore
      2. Notchman | Jan 02, 2009 08:38pm | #29
        The threaded part of mine has a rounded root rather than a v-cut bolt thread, which makes them a bit more debris friendly....though you do want to keep them clean...especially on concrete jobs.Portland is over 200 miles from me and, being accustomed to and fond of living in a less-populated backwater, I avoid it like the plague.I think I've heard it called P-Town, but I was in the Navy with a guy from Beaver Falls, PA who used that nickname for Pittsburg.
        1. Riversong | Jan 02, 2009 10:36pm | #30
          Careful, guys. P-Town out east is Provincetown MA at the very tip of Cape Cod, and it's the flaming g-a-y culture center of the East Coast.
          Wikipeida: In the mid-1970s members of the g-a-y community began moving to Provincetown. In 1978 the Provincetown Business Guild (PBG) was formed to promote g-a-y tourism. Today more than 200 businesses belong to the PBG and Provincetown is perhaps the best-known g-a-y summer resort on the East Coast.<!----><!----><!---->
          <!---->Of course, Portland OR is now the largest US city with an openly g-a-y mayor, so you Left Coasters are in the ballgame, too.
          [What is with this forum that it censors such a non-controversial word as g-a-y!]<!---->
          Edited 1/2/2009 2:38 pm ET by Riversong
          1. MikeSmith | Jan 02, 2009 10:58pm | #31
            wiki is wrong again..... P'town was  half g-a-y when i got  there in '69
            it was  a very easy going town.... there was the art colony....the theater colony.... the writer's colony.... the potuguese  fishing colony.... anf by  the time i got there   there were tons of hippies...
            i would  think  P'town  was  a g-y colony  from at least the '50's
            quite the culture shock for someone just  comming off 4 years in the army..... but i managed to acclimate....
            the fishermen loved us....  they  had been waiting 50 years for that  breakwaterMike Hussein Smith Rhode Island : Design / Build / Repair / Restore
            EricPaulson | Jan 03, 2009 02:05am | #36
            .......and when you left?
          3. MikeSmith | Jan 03, 2009 02:14am | #37
            that's where i met helen....Mike Hussein Smith Rhode Island : Design / Build / Repair / Restore
            EricPaulson | Jan 03, 2009 02:20am | #38
            Helen the Hippie!
            That says volumes. I've been trying to figure you two out for a while now.................
            I can see her now; halter top, head band and bangle earings.
            Got any pics?
          5. MikeSmith | Jan 03, 2009 02:34am | #39
            i'll tell you all about it at jlc..... this is your year to buy, right ?Mike Hussein Smith Rhode Island : Design / Build / Repair / Restore
            EricPaulson | Jan 03, 2009 02:43am | #40
            Hmmmmm.
            The way things have turned this past week, I'm holding on to hope I can even get there. I was looking to sign up yesterday just to commit the funds while I have them.
            Hey, with the dough you made last year "buying" that might get me gas to get home!
            Can't wait to hear the story, make sure you bring the pics of that sexy bride to be!
          7. User avater
            FatRoman | Jan 03, 2009 03:39am | #42
            If I'm going to JLC, I'd be happy to give you a lift.Hopefully we don't have to beat out the mayor for a table again this year. And maybe, given the drift of this thread, Mike will regale us with some tales of yore from P-town.'Man who say it cannot be done should not interrupt man doing it' ~ Chinese proverb
          8. MikeSmith | Jan 03, 2009 04:16am | #43
            you gonna bring your new Mac ?Mike Hussein Smith Rhode Island : Design / Build / Repair / Restore
          9. User avater
            FatRoman | Jan 03, 2009 04:34am | #45
            I hope so!'Man who say it cannot be done should not interrupt man doing it' ~ Chinese proverb
          10. User avater
            EricPaulson | Jan 03, 2009 04:24am | #44
            Thanks for the offer, I'll keep that in mind as the date draws near. I'm jonesing to get signed up.
            Guess that's just a sign of a need to learn something new.
            Mike and a bunch of just out of the  Army guys descending on P town. There has got to be at least a couple of good stories there.
          11. User avater
            FatRoman | Jan 03, 2009 04:36am | #46
            As long as there are no stories of 'the best meatballs I ever had' we should be safe.Had a great time there last year, so I'm planning on going.'Man who say it cannot be done should not interrupt man doing it' ~ Chinese proverb
          12. User avater
            EricPaulson | Jan 03, 2009 04:50am | #47
            My best have raisins in them!
            sorry
          13. Bing187 | Jan 03, 2009 07:50pm | #50
            That's not why the fishermen loved you...;)
          14. davidmeiland | Jan 02, 2009 11:04pm | #32
            I use the Ellis adjustable wall braces (same as Mike's) and I nail them to the sides of studs right at the top, right under the plate if that's what's easy. We get excellent 2x6 KD #1 Fir most of the time and it doesn't matter at all that we're pushing the studs and not the plate. We generally walk the plate when rolling joists and I don't want anything sticking up in my clumsy-arse way.
            edit--you can no longer say 'a-z-z'
            Edited 1/2/2009 3:05 pm by davidmeiland
          15. Notchman | Jan 03, 2009 12:24am | #33
            That "left coast" tag amuses me: In a geography of wide open, rugged spaces, populations of Ranchers, loggers, Fishermen, farmers and millworkers....lots of veterans, etc., me thinks whoever came up with that has never been out here and if so, just hunkered down at a fern bar one afternoon in one of the larger cities.
          16. davidmeiland | Jan 03, 2009 12:46am | #34
            Word.
          17. MikeSmith | Jan 03, 2009 01:40am | #35
            hey...  i wuz born on the left coast....  raised on the right coast
            i love fern bars too, and biker bars,  it's all goodMike Hussein Smith Rhode Island : Design / Build / Repair / Restore
  3. Chucky | Jan 02, 2009 04:41am | #17
    Lee Valley sell these for $31.50.  Free shipping until January 4th.
    http://www.leevalley.com/wood/page.aspx?c=2&p=44908&cat=1,43838,47843
    1. DanH | Jan 02, 2009 03:27pm | #25
      Yeah, I've got a couple of those from Aircraft Spruce. They can pull as well as push, work with cable or chain. Probably not as handy for straightening a wall, but more versatile.
      The mark of the immature man is that he wants to die nobly for a cause, while the mark of a mature man is that he wants to live humbly for one. --Wilhelm Stekel
    CaptainMayhem | Jan 02, 2009 08:43am | #22
    So are they worth the trouble? I Bthaught that they seemed to have saved alot of time..plus if you used a bunch, couldn't you ensure that your wall is "perfect"?
    1. ANDYSZ2 | Jan 02, 2009 11:40am | #23
      I like using 20' tie down staps with cranks.
      You can rack a 40' 2x6 wall without a sweat and trying to do it with a bowed 2x10 wouldn't even move the wall.
      You can buy a set for less than 20$ and they store nicely.
      ANDYSZ2
       WHY DO I HAVE TO EXPLAIN TO FRIENDS AND FAMILY THAT BEING A SOLE PROPRIETOR IS A REAL JOB?
      REMODELER/PUNCHOUT SPECIALIST
  • Cultivating Company Culture
  • Choosing a Paintbrush
  • Rainscreen for Cedar Shingles
