What is the best way to attatch stranded copper to receps and switches? Any tricks out there.
I am sure a Chicago sparky would know….
“It is what it is.”
“It is what it is.”
This centuries-old paint offers vapor-permeabiity, maintainability, and longevity with zero VOCs, but know its limitations before you get to work.
The first thing is to twist insulation as you "unscrew it" to tightly twist the wire.
If you are careful then put it around the screw.
Or even better you can use the backwire devices (but the receptacle run about $2-2.50). they will take the stranded wire.
Another trick is to strip off about 5/8" insulation.
Then stripe back another 1/8" and carefully unscrew it until it is rgith at the end of the wires. That forms a sleave that holds all of the wires together.
Or use these http://portal.fciconnect.com
Insulated split connectors work just fine.
A lot safer and faster for most DIY's.
That's a great idea! I've never thought of that. When I moved to NY from Chicago, I brought about 30 rolls of wire with me. I know you can use romex here, but I can't see using romex when thinwall is so cheap and I know how to bend it. I am going to use it in my home with the stranded wire.
"It is what it is."
if wire is stranded, first you have to rescue it...
badoom tissshhh
"After the laws of Physics, everything else is opinion"
-Neil deGrasse Tyson
If Pasta and Antipasta meet is it the end of the Universe???
I guess I have to get up pretty early in the morning to beat you at the bad jokes... lol
I was going to suggest giving it a ride.
I refuse to accept that there are limitations to what we can accomplish. Pete Draganic
Take life as a test and shoot for a better score each day. Matt Garcia
Dude! comon.........
Good one liner!
"It is what it is."
Tahnk you all.
Pete, I have seen your idea used alot in older homes. I ahve seen it when I was doing demo.
"It is what it is."
I built an addition as a photographer's studio.
All wall receptacle wiring was run in PVC conduit with stranded wire - this was done to facilitate any future changes in power requirements.
Stranded wire was connected to switch / outlet screw terminals via crimp on, insulated, split terminals - inspector here loved it - works perfectly.
Suggest you buy a good set of crimpers which crimp both the wire connection and insulation in one operation - yank on the finished crimp to check your work.
Jim
I like Bill's sleeve.
But my trick over the years has been a small metal cap from a spray can, or a 1" copper cap. I either sit it on the stove or hold it in visegrips and heat it. Then I fill it full of non juicy solder. I then dip the stripped piece of twisted wire into the solder - after dipping it first in flux cleaner. Gives me a nice tinned solid wire.
Then I let the cap cool and put it in the electrical drawer for the next time. I've had one of these hanging around for at least the past 30 years.
The crimp-on splits work great. Harbor Freight has a nice set of racheting crimpers that do them much better than most of the usual ones you see except for the very high $ ones.
http://www.harborfreightusa.com/usa/itemdisplay/displayItemList.do?search.keyword=crimper
