Strange sediment in hot water lines
| Posted in General Discussion on January 19, 1999 07:01am
Light blue granules have been clogging
faucet strainers, shower heads and
dishwasher solenoid valves. Trace
amounts were noticed about 1 year ago
but did not pose the clogging problem
that I’m experiencing now. It seems
isolated to the hot water lines. I
flushed the water heater and filtered
the water through a fine strainer.
About a handful of this sediment was
trapped: it is actually gel-like in
consistency, light green-blue in color
with whitish granules. I replaced the
water heater yesterday and haven’t
opened up the old one yet to see what is
inside. What is this stuff and is it
toxic? Some background: the heater is
a Kenmore Economizer 5, 30 gallon,
gas-fired model about 16 years old.
Ours is an old house (70 years) and we
had the supply piping replaced with
copper when we moved in 1 year ago. We
kept the existing water heater and only
had it relocated. Also, there is a
light green/blue stain under the hot
water faucet on an enameled cast iron
pedestal sink (original fixture). I
think the stain developed after we moved in. Help solve the mystery.
  1. Guest_ | Jan 19, 1999 01:30am | #1
    Gint, I have EXACTLY the same problem. I have tried to find out what is causing this too, but I haven't had much luck. I have a water softener....Maybe this has something to do with it. On top of that, I also have a hot water recirculating system which kicks this stuff up and out into the system. I put a ball valve and a piece of copper tubing shaped like a big Roman faucet on the drain of the water heater so I could easily and forcefully flush it out. This helps, but I finally got a high-temp water filter and installed it just above the heater. This finally solved the problem of the clogged screens etc. I got it at Graingers for about $65.00. That's what I would do if I were you. The filters last about 6 months before they need replacement.
    1. Guest_ | Jan 19, 1999 04:37am | #2
      *I cannot help but think that this is copper salt which is coming from either the copper pipes in your local water distribution system, or from the copper pipes after the water enters your property. There was a big story about this locally when a whole development experienced this same thing, "blue water and blue granules". As I recall, when they found the source, it turned out to be a series of failed and failing dielectric unions installed by the water company that were the culprits. To see if this material is in fact some sort of copper salt, there is a simple test you, yourself can perform to find out. Take some of these blue granules and let them dry out thoroughly. Maybe half a teaspoon, should be more than enough. Then, with saftey glasses firmly sitting on your nose, heat them up under the direct flame from a butane torch. Use the inner, light blue, flame cone to get the maximum effect... If the resultant flame turns bright green, then these are indeed some kind of copper salt. If the flame does not show green, then they are not copper salts and you will have to look elsewhere for the answer to your blue granuals question. When you perform the test, be sure not to blow the granules away with the flame and give the flame 20 -40 seconds to completly heat up the granules before stopping the test. A bright green flame indicates the presence of copper. To get an example of what your looking for, do the same test first on a 12 to 14 inch long piece of copper wire.
  2. G.LaLonde | Jan 19, 1999 05:41am | #3
    Steve, I will try this to amuse myself, if nothing else! This stuff forms in the bottom of the water heater. The inside of my cold water lines are like new. The inside of my hot water lines are coated with green material. I'll let you know what I discover. Thanks for now.....
  3. Guest_ | Jan 19, 1999 10:00am | #4
    This stuff is frozen hot water. As we learned from another thread hot water freezes first. The reason it does not melt is because it has a higher melting point than frozen cold water, therefore you have to get it very hot to make it melt. This is also why there is none in the cold water pipes. The cold water is hotter than cold ice, so it melts. When the hot water gets colder than the hot ice, the hot ice will not melt.
    1. Guest_ | Jan 19, 1999 10:23am | #5
      *Unfair, Mike!I'm recovering from a blown out back and you had me laughing so hard I'll be on bed rest another two weeks!Nice one, Mongo
  4. Butch_Uhlhorn | Jan 19, 1999 07:01pm | #6
    The sediment that you describe is from the dip tube breaking apart. Contact the mfgr and they may pay for replacement. They paid $150 to replace mine a month ago and the problem stopped at once.
    Butch
    1. ItchyPits | Nov 23, 2021 08:51am | #12
      The dip problem that existed 20 years ago was indeed real; but the sediment wouldn't haven't been blue. They way one checked, was to drain and flush water heater and strain the water to see if any dip tube plastic showed in the strainer. At some point some much dip tube disintegrated that the cold water was not being pushed down to the heater. It was a defect and usually fixed by manufacturer. Shouldn't be any surviving dip tube defects by now I would think. The blue stuff is likely from the anode; replace with magnesium rod.
  5. Gint_Lietuvninkas | Jan 19, 1999 07:01pm | #7
    that I'm experiencing now. It seems
    water heater yesterday and haven't
  6. s.arvy | Nov 30, 2015 03:17pm | #8
    I have this same problem and it is causing the water valve in my washing machine to fail every 9 months or so.  Did you ever solve this problem?
    1. DanH | Nov 30, 2015 04:05pm | #9
      It's a 16-year-old question, but the likely answer is the lack of a proper dielectric union between iron and copper pipe somewhere.
  7. Naeco | Mar 28, 2019 09:38pm | #10
    Thank you for posting this! 18 years later, and this was the first thing that popped up in a Google search when I was trying to figure out what the blue green sediment was in my apartment shower.
  8. ItchyPits | Nov 21, 2021 10:36pm | #11
    Nope, not the dip tube. It's most likely the anode rod, often made of aluminum, and in the water heater. Part of the fix is switching to magnesium rod. See if this bulletin solves your problem: https://www.hotwater.com/lit/bulletin/bulletin14.pdf
  9. KonohaDance | Nov 24, 2021 12:32pm | #13
    As I understand it means that there is too much copper in the water right?
  10. User avater
    juegagerman | Nov 24, 2021 12:35pm | #14
    Looks like water contains too much copper.
Outdoor Lighting
  • A Postwar Comeback
  • Natural Simplicity
  • A Grand Rescue on the Coast
