Strange Sheet Rock Problem
WalterD | Posted in Construction Techniques on August 13, 2010 01:42am
Good Day –
I’m looking for help on a strange problem that’s happening on ome of my sheetrodking.
A few months after the job is finished and painted. some seams have 2 to 5 inch long sections that look like the mud has been forced out and left hard ridges about an eighth of an inch above the sheetrock surface.  No cracks, just a raised “eruption”
tThis is random and only on a few seams.  I don’t kow anything different about the areas that “erupt” and those that don’t.  Its a frustrating problem that messes  up an otherwise decent job.
Anyone out there have any ideas about what may be the cause?  Any ideas are most appreiciated
Walter D;
Newfane VT
  1. calvin | Aug 13, 2010 03:20pm | #1
    New construction or remodel?
    Sheets tight to the ceiling and tight to the floor?
    Framing that has shrunk sometimes produced what you see (if I understood the problem).
    or
    tape lifting or "bubbles" usually along the center of the seam, sometimes as a larger bubble-othertimes not wide-more like a line.
  2. DanH | Aug 13, 2010 06:12pm | #2
    My guess is the framing shrunk.
  3. Scott | Aug 13, 2010 08:47pm | #3
    What the other guys said. A
    It's a common problem in this day of green lumber cut from second growth trees = major shrinkage. The best solution is to let the frame dry out for a year before drywalling (this is what we did while I wired the place). I fully realize that this solution doesn't suit everyone's needs, but I can attest to it's results.
    I often feel sorry for the DW guys. They get blamed for all the nail pops and tape eruptions, but they were in no way responsible for the problem. I assume that most of them build all the callback time into their pricing, because it is a common problem.
  4. DanH | Aug 14, 2010 05:23pm | #4
    And are the bad joints parallel to the studs/joists or perpendicular to them?
