strap nailer for 16d nails?
slykarma | Posted in Tools for Home Building on September 12, 2011 12:18pm
About to start a commercial framing job and making my order for fasteners when I picked up an oversight on my part. There is an egineered detail that requires continuous Simpson strap in several locations, over 400 ft in total. I had assumed I’d be using the usual paper-collated joist hanger nails for my Bostitch Strapshot and was making a count for the order when I noticed that the engineer has specified 3″ (16d) nails for these straps. A check in the Simpson book indicates the same requirement. The Strapshot fires 1 1/2″ nails and can’t go bigger than that. Since I have over 5000 nails to set in these straps, an air gun would be a big money saver. Can anyone recommend a positive-placement nailer that can drive 3″ collated fasteners?
    MarkH | Sep 12, 2011 01:01pm | #1
    Bostitch F21PL will work (up to 3 1/2").  It is not a dedicated positive placement nailer, it comes with two nosepieces, so it can frame too. Note:A 3" nail is a #10, 3 1/2 is #16.  Make sure the shank is the right size, it's probably 8 or 9 gauge.  Should be specified on the plans.
    EDIT:
    Check with Bostitch since there are discrepancies on the length of metal connector nails it can use, I've seen 2 1/2, and 3 1/2 maximum length nails specified.
  2. oldhand | Sep 12, 2011 06:02pm | #2
    another option...
    The older bostitch N88 RH will shoot a 3" nail with the MCN nosepiece attachment.
    3 1/2" nail is a no-go.
    xxPaulCPxx | Sep 13, 2011 12:42pm | #3
    If it is a strap like the CMST12, you can use 16d OR 10d fasteners... but to use the 10d you need to use more and the strap section needs to be a little longer.  See the table here:
    http://www.strongtie.com/products/connectors/CS-CMST.asp
  4. davidmeiland | Sep 15, 2011 08:14pm | #4
    Hitachi strap
    nailer shoots 2-1/2" x .148 paper collated nails. Might be worth asking the engineer if those are massive enough.
Grout-Free Shower Panels
