Strength of Pressure Tr. vs S. Yel. Pine
BilljustBill | Posted in General Discussion on August 5, 2007 05:59am
What is the strength difference of a pressure treated 2×6 vx a standard Standard Yellow Pine 2×6?  Can pressure treated lumber be used for rafters?
Thanks for your insight,
Bill
    EricPaulson | Aug 05, 2007 02:02pm | #1
    PT these is is ACQ and as far as I know it is almost all southern yellow pine.
    NO.
    Depends.
    [email protected]
    BillHartmann | Aug 05, 2007 02:55pm | #2
    PT WHAT?
    If you are talking about stock lumber, most (all) of it east of the rockies is SYP.
    On the west coast (or parts of it) they use different wood.
    and what is the application? there is a derating for wet applications.
  3. Piffin | Aug 05, 2007 04:48pm | #3
    In Texas, I assume that the PT IS SYP!
    I don't see why it could not be used for roof framing, but why spend all that extra money for the lumber and for the SS fasteneres?
    1. BilljustBill | Aug 05, 2007 06:40pm | #5
          ...why spend all that extra money for the lumber and for the SS fasteneres?
      Hi Piffin,
         When the local Home Depot's new manager started about 18 months ago, she started a "new policy".  All their culled lumber is now cut into 4' lengths and buried in a landfill, so I started buying the "Cull Carts" at Lowes.
        Many times the pressure treated lumber has just dried too fast on one side causing it to look like a boomerang....  When wet with the garden hose and allowed to dry evenly, 75% of the boards straighten out....  Last night I bought $197.00 of culled lumber for $20, and on the cart were half a dozen pressure treated 16' long 2x4's, some Red Cedar, and 22 pressure treated 10' long 1X4's.  When I get this pressure treated lumber, and out of the long pieces I can cut an almost perfect 8' or 10' length out of it, if not use the whole board, it is too good of a value  to pass-up, even if I have to buy galvanized nails....
        Last summer I built a 10'x20' and a 12x12' Victorian style raised bed planters, and except for having to buy new 4x4's to make the decorative posts on the bandsaw, I used the ACQ pressure treated lumber found on cull carts.  Wet down and using clamps to pull the 2X6 lumber straight, it cost me about 12% of new pressure treated wood. Galvanized lag bolts came by the pound from Tractor Supply.
         Jim's link to Southern Yellow Pine "end uses" is a great site.
        Thanks for everyone's help.
        Bill
      1. Piffin | Aug 05, 2007 06:50pm | #6
        OK, I remember your situation now
  4. JimB | Aug 05, 2007 04:52pm | #4
    I don't think that treated SYP has the same design values as non-treated SYP.  Here's a link that has probably more information than you want http://www.southernpine.com/
