stress skin and moisture problems?
| Posted in General Discussion on August 27, 1999 08:00am
Jean, please post your question on Breaktime, Fine Homebuilding’s message board,
at http://www.taunton.com:8090/WebX?14@@.ee6b303.
Ruth Dobsevage
web editor
[email protected] (Jean A. Dietrich) on 08/24/99 10:12:29 PM
To: [email protected], webeditor
cc:
Subject: Question from FH Online
Hi,
We have a post and beam house that is wrapped in stress skin panels. It is
built into a hill with the north side roof coming almost to the ground. We have
and are still having lots of problems with moisture. The northside roof leaked
and we replaced it by taking off the old roofing, down to the foam, and
attaching 2×4’s to the roof beams, then laying plywood on top and re-shingling.
At that time we added a ridge vent and a vent between the old roofing and the
new roofing. I have seen signs of carpenter ants lately and I am really
worried. Venilation in our house is not very good either. Where do we get
help?
  1. Jean_Dietrich | Aug 27, 1999 08:00pm | #1
    Jean, please post your question on Breaktime, Fine Homebuilding's message board,
    Ruth Dobsevage
    web editor
    cc:
    Hi,
    attaching 2x4's to the roof beams, then laying plywood on top and re-shingling.
    help?
  2. Guest_ | Aug 27, 1999 08:00pm | #2
    Hi Jean,
    I would like to help. First though, more
    information is needed:
    Are your moisture problems mostly concerned with
    the roof, or is that north side wall a problem
    too? I assume that north wall is composed of some
    type of masonry. How is your house sited? Are
    there trees sheltering and dripping moisture on
    your roof/siding? Are you getting a ground
    moisture problem from siding too low, grade too
    high, sill draining inward, etc.? What types of
    roof vents did you install? Is there attic space
    or a fan? What kind of moisture barrier does the
    house employ? Any details on drainage and your
    location as regards to rainfall,snowfall, and
    humidity are helpful.
    As to ants, a local pest control expert can do you
    a lot of good.
    Give us some details and we'll try to help.
    Sco
Picture-Perfect Pergola
