Stripped Key Gas Valve
aa_ron | Posted in General Discussion on December 20, 2021 09:26pm
I just purchased a home with an outdoor firepit. The gas valve is the standard key valve and the previous owner stripped the valve stem by using the wrong size key.  I would just replace the valve, but it is set into the concrete. Meaning the valve itself is encased in concrete and I can’t get to it without cutting / chipping up the concrete.
Is it possible to replace the key stem portion without pulling out the whole valve? Or am I looking at cutting up the concrete to replace the valve altogether?
Thanks in advance for your help!
    unclemike42 | Dec 21, 2021 08:15am | #1
    Look closely at the bottom of the square key hole. if there is a screw, you may be able to pull the square mating part off as you would pull the handle from a faucet, then search for a suitable replacement.
  2. mikemahan3 | Dec 21, 2021 01:25pm | #2
    I just had to deal with this. All the parts are replaceable through the. front with a few tools.
  3. mmgasvalve | Jun 11, 2023 10:17am | #3
    i have the exact same problem. did you ever find a solution?
