Stripping black paint from Oak stairs
Comic | Posted in General Discussion on September 1, 2005 01:35am
I am rehabbing a house that has a beautiful circular staircase. Unfortunately the previous owners painted the oak treads a high gloss black. Has anyone had any luck using a particular stripper to remove paint from oak? I have to minimize any sanding because the painters just finished up the walls. I want to strip the stairs and refinish with a poly to the original look. Thanks for any help.
  1. paintergal | Sep 01, 2005 03:37pm | #1
    Soygel. No dust.
  2. PenobscotMan | Sep 01, 2005 03:59pm | #2
    About oak -- it is a very porous wood, and the pores absorb paint.  So, even if you strip the surface paint, you may get a very grainy effect as the paint in the spring wood (the part of the annual ring with the big pores) shows up.  I'd strip a bit before you commit to stripping the entire project, as you may be disappointed with the result.  Sorry for the pessimism.
  3. bluethumb | Sep 01, 2005 04:09pm | #3
    I stripped painted oak trim in my living room & dining room with excellent results.  It was unpleasant, tho.  I used a heat gun to strip the numerous coats of paint, and then used a methylene chloride stripper & 3M scrubber pad to remove residue and stuff soaked into the grain.
    MC strippers are nasty, but they work quickly.  I would suggest using a respirator while using it - it will also strip your brain.
    I have also used 3M Safest Strip which is apparently mild enough to use as a coffee creamer;  It works too, albeit taking a longer time to do its job, and it requires more elbow grease.
    Lotsa luck.  It is a labor-intensive project you have there, but you can make the stair beautiful again.
  4. BryanSayer | Sep 01, 2005 06:11pm | #4
    In terms of sucking pigment out of the pores, we had pretty good luck with Peel-Away. Any thick paste remover with a backing of some kind should do the same. For most things we have switched to Soygel. Works reasonably well, but haven't tried it on oak yet.
