Stripping Paint with Steam
Snowmon | Posted in Construction Techniques on June 15, 2006 08:23am
John Leeke on steam paint removal:
Maybe someone posted on this before, but it’s news to me!
http://historichomeworks.com/forum/viewtopic.php?t=133
http://www.oldewindowrestorer.com/steamstripper.html
  1. SR | Jun 16, 2006 02:17am | #1
    Thanks for the link.  Looks like a good idea.  Way better than chems., heat gun, disks, pads, knives, blades, brushes, etc.  I'll give it a go next time.
    1. MadisonRenovations | Oct 21, 2009 12:18am | #2
      Last weekend, I spent a couple hours and quite a few trips up and down the ladder applying 5f5 waiting taking off a few layers, repeat, etc. while stripping a sill for a double window. There were still a couple layers that just weren't coming up before dark. (How much lead was in there in the old days, seemed near 100%) Because of the old paint probably back to 1920's when the house was built, I wanted to be careful to not get flakes/dust everywhere (so the 5f5 to turn it to mush), but because of the chemicals, I had to work from the outside.
      I read this thread and this morning went to Target to buy a $35 Conair compact fabric steamer. It's a small unit you put on the floor and has a hose with a head that looks like a small vacuum.
      After a few minutes to get the steam rolling, and about a minute keeping the steam head in one place heating up the paint, I pushed my putty knife taking up all 14 layers of paint moving across the sill (the width of the 2" 5-in-1) in about a minute or two. It still needs a little clean-up for residue, but no layers remain.
      Because there are no chemicals and it's not hot enough to vaporize the lead, I could do it from inside through an open window. If you consider the cost of strippers, this thing will pay for itself soon enough.
      Just thought I'd pass it along.
      edit: jump to short video of process http://forums.taunton.com/tp-breaktime/messages?msg=75047.32
      ---mike...Madison RenovationsCambridge, Mass.
      Edited 10/24/2009 6:20 pm ET by MadisonRenovations
      1. TommH | Oct 21, 2009 01:52am | #3
        very interesting. It sounds like you use it like a heat gun, but without the negatives...burning the wood etc. Can you post some photos?
        1. MadisonRenovations | Oct 23, 2009 09:41am | #31
          Attached are a photo and a couple of videos of the process.  The video without the steam head is to show that the paint wasn't flaking off on its own.  All layers were stripped, although some residue remains that I plan to hit with a short, light coat of 5f5 then wash with mineral spirits.
          ---mike...
          File format File format
          1. TommH | Oct 23, 2009 04:41pm | #32
            Wow, pretty impressive and no gloves even! I like the sound effects. I may have to retire my heat gun.
          2. Piffin | Oct 23, 2009 10:10pm | #34
            Thanks for bringing this up!I ordered a Jiffy 4000I like john leeke uses.
            The makers website had me at about $372 for the unit I wanted, but I found same one on Ebay for about 250 plus shipping. I have a room full of wall paper to strip and some painting to prep. Anticipating using it more.
          3. betterbuiltnyc | Oct 23, 2009 10:18pm | #35
            Interesting indeed. I wonder if this removal method would be classified as mechanical removal by the EPA...the DOB is very strict about scraping/sanding paint here for fear of lead paint.
          4. MadisonRenovations | Oct 29, 2009 03:53am | #36
            The interesting thing about this method is that it softens the paint there is *no* dust. As long as you are careful about the waste, it is easy to contain. Because it is relatively low temperature, there are no fumes, only water vapor. There are no toxic (or any) chemicals, just water, to release to the environment. It does use electricity, however.I would not call this the only stripping method I'd use. It is very useful for stripping in place, so you don't have to worry about chemicals dripping off the surface, losing effectiveness and possibly stripping surrounding areas. If you can strip in one pass with a gel stripper, that is probably less effort and used time (if you can do something else while it's softening the paint). If it'll take multiple passes with gel, as with my dozen-plus layers, then steam might take less time.It seems to work best on many layers of oil-based paint, which makes it different from most methods. It seems to be least effective on a single layer of latex, maybe because that's the softened wood where the oil paint flaked off, so the latex really got into the wood, and the surface wasn't smooth for scraping. Removing thick layers was easiest with a putty knife; latex seemed to go better with a pull scraper.One thing that helped was making sure the steamer was heating the putty knife or pull scraper. It could then soften the paint from the bottom. It's easier to slip a putty knife under the steam head than a pull scraper. With my cheapo steamer, I had to keep the steam head within about a 1/4 inch of the surface or it wouldn't heat enough. Remember, it takes 212 degrees to create the steam, but steam can be cooler than 212 degrees away from the heat source (example: fog).It took some maneuvering to keep both the pull scraper and surface hot enough.Also note, my 35 buck steamer is probably not the best version of the tool. However, when I want to try a new stripper, I usually get a quart to test it out before I buy a gallon, but it's hard to get a quarter of an industrial steamer to work. This steamer is like a one quart test before you plunge in for a 200 buck model.Oh, and in the couple of sashes I've tried so far, it was unbelievable in softening the old glazing compound. I wish I had found this before.---mike...
          5. Piffin | Oct 29, 2009 02:11pm | #38
            Thanks for the added comments on technique.
            I got my Jiffy 4000 delivered yesterday, but was so busy I didn't even open the box yet.I restore a lot of old windows and the steam method really appeals to me there. When you have an antique window with old wavy glass you don't want to break it, which can happen with overheating with a heat gun.I may start mine up on some wall paper today or tomorrow
          6. Mike_Mills | Oct 29, 2009 06:58pm | #39
            A totally useless factoid follows:
            Steam is invisible to the eye.  Steam (water vapor) has a temperature of 212 F or higher.  When you see that whitish cloud of "steam" it is not actuallt steam, it is water droplets that have formed out of the cooled water vapor.  The most useful function of steam is the latent heat of vaporization.  In going from a gas to a liquid, steam releases a tremendous amount of heat.  It does not change temperature during this release but it gives off a tremendous amount of heat.
          7. Don | Oct 29, 2009 08:08pm | #40
            Mike: Totally USEFUL!!! Tells people why they can get so badly burned by steam they cannot see. Especially if it comes out of a pressure vessel, where it is superheated.DonDon Reinhard
            The Glass Masterworks
            "If it scratches, I etch it!"
          8. RickD | Oct 29, 2009 08:11pm | #41
            I have a commercial steamer (Earlex, bought on ebay for $100, same as the rentals) which I use from time to time.
            The stupid, I can't believe it took me so long to think of it, trick I found was to always fill the tank with HOT water.  Fill that big tank with cold and it's at least 30 minutes before anything happens.
            I am surprised just how dumb I can be sometimes -
          9. alias | Oct 29, 2009 08:13pm | #42
            Would appreciate you keeping us posted on the unit and technique... Thanks
          10. Piffin | Oct 29, 2009 09:53pm | #43
            Yes, it may be a wwhile. I fly to Florida for a week come sunday and things hectic gettin gready
          11. xMike | Oct 29, 2009 10:14pm | #44
            Well, we've marked the thread as "high interest" so when you get back, report! :)
            Mike
          12. Piffin | Oct 29, 2009 11:43pm | #45
            Well, ya never know, I might be in the mood for steam come morning, but I have a feeling that getting a bill out will be more important. That way I'll have a check to deposit when I get home.
      2. TommH | Oct 21, 2009 01:54am | #4
        Went to the Conair website...many models. Which one did you use?
        1. MadisonRenovations | Oct 21, 2009 02:16am | #5
          >Went to the Conair website...many models. Which one did you use?<grumble, grumble> The one that's 2 bucks cheaper on the Conair website than I paid at Target, and 5 bucks cheaper at Amazon: the gs33r - $34.79 at Target.Well, I decided to get one yesterday, and had my first sill stripped with it today.Showed it to the lead painter (pronounced "leed" not "led"), and he said he had to get one. And it can get the wrinkles out of you clothes, too. I was worried that it wouldn't get hot enough, but it does where it's needed, and I didn't need gloves. It's not super fast, but fast enough.By the way, it was the paint between the storms and the double hungs on the north side, no weathering at all. It was solid paint that ignored a cold putty knife as if the lead was an armor shield.---mike...
          1. TommH | Oct 21, 2009 05:55pm | #18
            Hold the grumbles. Once they add the shipping charges, it would cost you more.
          2. MadisonRenovations | Oct 21, 2009 06:08pm | #20
            >Hold the grumbles. Once they add the shipping charges, it would cost you more.Oh, I know. In addition to shipping charges, time is also money, so it was worth the cost difference, but I wouldn't expect Target to be selling above the MSRP shown on the Conair site.
      3. RedfordHenry | Oct 21, 2009 04:52am | #6
        Sounds like a heat gun on low.  I wonder if a cheap hair dryer wouldn't work just as well
        1. DanH | Oct 21, 2009 05:32am | #7
          The advantage of steam is that it carries a lot of heat at relatively low temperature -- able to heat the surface better without burning it.
          As I stood before the gates I realized that I never want to be as certain about anything as were the people who built this place. --Rabbi Sheila Peltz, on her visit to Auschwitz
          1. MadisonRenovations | Oct 21, 2009 06:40am | #8
            >The advantage of steam is that it carries a lot of heat at relatively low temperature -- able to heat the surface better without burning it.The temperature is pretty much capped at 212 degrees F, because at that temperature, the water floats away and can't be heated any more. This is important not just to prevent burning wood, but also to prevent vaporizing lead. Since the temp. is limited, you can keep the steam head in place for longer than necessary without reaching the lead vaporization point.Also, water is often responsible for paint failure when it gets behind the paint. The steam method supposedly gets water vapor behind the paint.All I know is that it works better than I expected, and I feel safe doing it - no caustic chemicals, no fumes, no lead/paint vapors, no dust, no accidentally burning down the house. It is possible to get burns from the steam if not careful.By the way, my technique differs from what I have read, which keeps the steam head in one place until it loosens all the paint under it, then scrape all that section in a quick pass. Instead, I keep the head in one place for some time at the start, then when it's soft enough to scrape, I keep the head moving forward as I scrape with the putty knife at the tail end. The scraping action is a little slower, but it's a continuous, smooth motion, and it only heats for as long as minimally needed. As soon as there's enough heat to lift the paint, the putty knife moves on to the next spot.---mike...
          2. DanH | Oct 21, 2009 06:43am | #9
            My point is that the heat content of steam is much greater than hot air of the same temperature. So you can heat more paint with less steam. With hot air you can't really get enough heat on the paint without turning up the temp high enough that you're in danger of burning stuff.
          3. DanH | Oct 21, 2009 06:44am | #10
            Your technique sounds a bit like steaming wallpaper (when steaming works).
          4. MadisonRenovations | Oct 21, 2009 07:58am | #11
            The technique isn't earthshattering; it just seemed to be different that what I read. I haven't steamed wall paper, but I think it doesn't work well for vinyl coated paper because the vapor barrier doesn't allow re-wetting of the adhesive. I don't think paint is quite the same beast.I agree with you about the heat content of water vapor; I was just pointing out some details and other observations.
          5. DanH | Oct 21, 2009 03:20pm | #15
            Yeah, wallpaper steams very easily or not at all, depending on whether it's coated or not (and most these days is, even if not visibly). (And, no, those "paper dragon" things don't do much good.)
          6. dtown | Oct 21, 2009 03:39pm | #16
            I have been using steam for the removal of glazing from 100 year old sashes.  I built a box out of foil faced rigid foam insulation.  It holds two typical sashes vertically.  It is held together with a 1x3 exoskeleton with a hinged door.  At the rear I feed the outlet pipe of a commercial steamer I bought on craigslist.  I pop two sashes in at a time then work on other things for 30 minutes or so.  When time is up I pull one out and run a pull scraper around the glazing to harvest the wavy glass out in one piece for reuse.  I then run the scraper around the sashe itself to get what paint is lose enough at that point to remove.  Cooking longer get more of the paint loose but I typically just use the infrared stripper to get the rest.  The advantage for me has been the ability to preserve the historic glass in one piece.  A heat gun causes too many temperature differentials for the already fragile glass to handle.
          7. MadisonRenovations | Oct 21, 2009 05:15pm | #17
            regarding a steam box for sashes: Do you know what temperature the box gets up to?My little fabric steamer works pretty fast when the steam head is a 1/4" away from the paint, but I don't know if it would work to feed a sash-sized steam box. I need to do a few more sashes in addition to the sills, and soaking it would reduce my time with them. Can't do the same for the sills, though...Any wood damage by soaking it for a long time? Do it need to dry out?And if you know: any issues with speed drying the oil-based primer on the empty sashes with a heat gun before applying the glazing compound?As you may be able to tell, I'm in a rush to take care of windows while the weather is giving us an Indian Summer.---mike...
          8. dtown | Oct 21, 2009 06:06pm | #19
            I do not konw the temperature.  The unit I have is a commercial unit I picked up from a retiring seamstress.  The wood comes out with that distinctive 100 year old, wet house smell.  I partly use the infrared stripper to take care of any moisture issues in the sash.  They typically sit for a week before I prime and glaze after stripping.  There is much epoxy work on some so expediting hasn't been neeed.
            Hope that helps....
          9. FingerJoint | Oct 21, 2009 06:27pm | #21
            Of course this little tid-bit comes up 6 months AFTER I spent $400 on a Infra Red Silent Paint Remover!  I have a garment steamer in the basement already!
          10. Karl | Oct 21, 2009 08:22pm | #29
            I saw a few online accounts of the silent paint remover and also found an account of a home made one.I was not in a position to fork out the money on the spr or the parts/time to build one. As I pondered the concept it dawned on me that we had a 20 year old "quartz" heater sitting in a pile for the goodwill.I disassembled the stand, disabled the "tip over" safety switch and it worked fantastic at heating the paint until it bubbled up.I saw another quartz heater at a yard sale for three dollars last week.The nice thing about the heater is it covers 6 by 30 inches at 1500 Watts. I am primarily stripping doors so the large area is really helpful.The official Infra Red Silent Paint Remover likely has safety features my improvised infra red paint remover lacks but with a bit of caution and awareness I think it is a great alternative to spending $400 should anyone else be thinking of buying one.Karl
          11. user-7123191 | Aug 06, 2018 08:38pm | #49
            nice suggestion to give this forum. i want to use a best quality steamer  at home but i on't have an idea about itself.
            if anybody have idea so please tell me about
          12. mrsludge | Oct 23, 2009 07:29pm | #33
            I attempted to build a steam box for re-doing sashes at my place. Probably due to insufficient  exoskeleton, but it didn't hold up all that well. The taped seams also came loose (I'd tried regular and mastic-backed foil tape), etc.
            I ended up just using the wand on the steamer held against the glazing. For my windows at least, this has worked just fine. Steam with one hand, scrape the old glazing off with the other, keeping the steamer ahead on the next spot to scrape.  It does get some of the paint off, especially if it's already crazed/cracked/peeling, but it was taking too long for me to consider using for removing all the paint.
            I have used it outside on sills a little and it worked well there. I have a couple of sills to finish and a couple that I haven't started yet. Will probably use this and a combo of SmartStrip, since I have a partial bucket of it and no other current uses for it.
            FWIW, the steamer is also from Target, in the 1300 to 1500 watt range. Was about $50. Forget if it's a Conair or not. I chose based on wattage being closest to the semi-commercial one folks on Leeke's board were getting.
          13. user-7123191 | Jul 30, 2018 09:40pm | #48
            nice suggestion buddy!
            do you have an idea about good steamer which is use to homes??
            if you have so please tell me about this i really need it
          14. Piffin | Oct 21, 2009 07:46pm | #25
            http://www.oldhousejournal.com/magazine/2006/june/Get-speed.shtmlHere is the text description of a lot of these details being disccussed
          15. User avater
            xxPaulCPxx | Oct 21, 2009 09:13am | #12
            >>The temperature is pretty much capped at 212 degrees F, because at that temperature, the water floats away and can't be heated any more.<<While 212 is the top temp for water, it is not the top temp for steam. Steam gets much hotter than water. When you boil a pot of water, it will top out at 212... but your stove is still on and the pot keeps getting heated. Where does that extra heat go? It escapes as steam - which is NOT subject to that upper limit of 212 degrees.
            Tu stultus esRebuilding my home in Cypress, CAAlso a CRX fanatic!
            Look, just send me to my drawer.  This whole talking-to-you thing is like double punishment.
          16. MadisonRenovations | Oct 21, 2009 10:15am | #13
            >>When you boil a pot of water, it will top out at 212... but your stove is still on and the pot keeps getting heated. Where does that extra heat go? It escapes as steam - which is NOT subject to that upper limit of 212 degrees.As long as there is water in the pot, the temperature of the steam will be it's boiling point, which is 212 deg F if the system is not pressurized. The temperature of the pot will roughly be 212 also, if the metal is a good conductor, as all the heat would be conducted to the water. The temperature of the flame is a measure of heat, which gets transferred to the water, which converts it to steam. A lot of heat is absorbed by the water for the phase change to vapor. As DanH mentioned, water can hold more heat than air at a given temperature, so the heat is carried away by the steam at a lower temperature than the heating source. Steam can only get hotter if the water runs out with the heat source still going.Check out "superheated steam" in wikipedia.---mike...
          17. User avater
            xxPaulCPxx | Oct 21, 2009 06:47pm | #22
            Ahhhhh - thanks for that edyecayshun!
          18. Don | Oct 29, 2009 06:59am | #37
            Proof that the temp of the pot doesn't get beyond 212 (or thereabouts)/Old Boy Scout question - will a paper cup full of water burn if put into a fire. Answer is NO! At least it was in 1951 when I performed the experiment on a campout. Paper cup burned from the top down as the water boiled away.You cannot raise the temp of steam above 212 at Standard atmospheric pressure.You want fun, raise the temp & pressure to the point where water, ice & steam all exist at the same time. The effects are staggering. You can get some very interesting reactions.DonDon Reinhard
          19. MikeHennessy | Oct 21, 2009 02:50pm | #14
            " Where does that extra heat go? It escapes as steam - which is NOT subject to that upper limit of 212 "
            The extra heat goes to converting water to steam -- which carries heat away from the pan. That's why it won't get over 212° -- as the water boils, steam removes the excess heat from the liquid and carries it off to the surrounding atmosphere. Steam can get hotter, but only when contained under pressure -- like in a pressure cooker or a boiler.Mike HennessyPittsburgh, PAEverything fits, until you put glue on it.
          20. Piffin | Oct 21, 2009 08:13pm | #27
            The steam will only get hotter if it is kept under pressure
          21. Piffin | Oct 21, 2009 07:43pm | #24
            http://www.historichomeworks.com/hhw/video/spr-video.htmI googled for other more commercial tools to make steam removal work, thinking that a 35 dollar tool would have limited use. You can spend as much as 2500 on them, but some others in the 200 dollar range.This link is of a steamer being used for paint removal. Probably not for dial up onnections
          22. MadisonRenovations | Oct 21, 2009 07:54pm | #26
            re: 35 buck tool.I guess I should mention that exterior work isn't my thing, except on my own house, which only has a few more sashes and sills left to do, so I didn't need this to last very long. (Diamond muntins) But I didn't want to shell out a lot if it wasn't going to work. It worked surprisingly well, and a $35 test is a fairly low bar. You want to be convinced before you shell out a couple hundred.Plus I can steam clothes when I'm done the windows, and it doesn't take up a lot of space as an occasional steamer.Trick with this mini model is to start slow until you get the hang of it.
          23. Piffin | Oct 21, 2009 08:18pm | #28
            I was not criticizing your tool, only thinking that for ME to buy one that would see a lot of hours use in construction areas doing renovations, I figured something more potent would be the better choice. Something like this one...http://www.jiffysteamer.com/Products/index.asp?steamerCatId=5
          24. Karl | Oct 21, 2009 08:28pm | #30
            What is the hose made out of? I think I would grow frustrated with a 800-1200watt steam generator and have visions of putting a hose on a giant tea kettle on a 10k btu burner to get a really powerful blast of steam.Not sure what would be a good hose though??? Maybe buy the $35 steamer at target and adapt its hose and accessoriesKarl
      4. Piffin | Oct 21, 2009 06:50pm | #23
        Sounds fantastic!
  2. alias | Nov 28, 2009 08:55pm | #46
    Paul hope your holiday was good one , considering your loss . My condolences again . Was wondering if you have tried out that new steam unit yet??
    1. Piffin | Nov 29, 2009 07:06pm | #47
      yes,
      I tried it for ten minutes or so to do a few sq feet to see how it goes.Then when I got back, I put my daughter on it with a putty knife to strip all that wallpapper in the room in about 5 hours. Real slick and easy.Have not experimented with it on paint yet though.
      I just tiled the bathroom floor this week
