Hey,
Any of you guys have any experience using structolite over metal lathe? Do you mix it with portland cement or use the structolite straight? The surface will be finished with plaster and painted.
Listeners write in about ambitious projects and sinking patios before asking questions about old house specialists, attic headroom, and home shops.
Use it straight.
Any particular reason?
In our use of it I haven't found a need for the extra hardness that adding portland would achieve. It can be done, but what's the benefit?
I'm in the middle of a plastering project... I'm learning as I go and I'm definitely not a pro... Structo-lite is great, but it's not the easiest to screed and/or rub to a flat surface if you have a smooth finish in mind. For that reason, for the first time I'm experimenting with a sanded base-coat, rather than a perlite based one like Structo-lite. Whatever your finish coat is, be sure it's compatible with the base coat... Some finish coats are meant to bond with Structo-lite, others work with other kinds of base coats.
thanks for your input. I checked out your work... very cool stuff
My neighbor, a 4th generation plasterer, mixes a little lime putty in the Structolite.
Also, the trick with this over metal lath is not to use the edge of the trowel too much. Just float it on with the face. It takes a special touch (that I do NOT have).
Pete Duffy, Handyman
Just don't use a metal float...use wood and keep it smooth but porus.
If Blodgett says, Tipi tipi tipi it must be so!
TipiFest 06~~> Send me your email addy for a Paypal invoice to the greatest show on earth~~>[email protected]
I throw a little molding plaster in with mine, which makes it setup faster, and perhaps be a bit harder. Certainly not necessary though.
Just be sure that you bring the level up just shy of the finish level. You want your finish coat to be around 1/8" thick. If the finish coat is too thick it shrinks and makes spider web cracks, and doesn't adhere all that well either.
I've come to the conclusion that I can't do the finish coat all that well, and I'm bring the pros back to finish it off.
USG says not to use it over metal lath:
http://www.usg.com/navigate.do?resource=/USG_Marketing_Content/usg.com/web_files/products/prod_details/USG_Structo-Lite_Plaster.htm
-- J.S.
Not really, John. "Not recommended over metal lath when a smooth trowel finish is required."
Also, "Structo-Lite¯ Brand Basecoat weighs half as much as sanded plaster and is perfect for locations where an aggregate is not needed or wanted. Quick and easy to apply by hand or machine over gypsum or metal lath, Structo-Lite Basecoat mixes easily with water at the jobsite and is a good choice in situations where high thermal conductivity is needed. Available in regular or masonry formulation."
Yes, but only for a smooth trowel finish.
