Structural Rot Repair
mcf | Posted in General Discussion on January 28, 2007 04:30am
I am mid stride in the planning stages of a renovation to my home. I have addressed how I will navigate many of the challenges of remodeling a 55 year old home with balloon framing. I am using a contractor but want to have a clear scope of work for many of the remediation issues that will be conducted during the construction. This brings me to this issue. I need feedback on structural rot repair. Below is the description of situation.
My home is built on a slab foundation. The family room is sunk in about 18 inches. Along a block wall that defines the one wall of the family room there is a section that has sustained water damage. This includes plaster damage as well as sill and stud rot. The sill and studs sit above grade. The damage was caused by a down spout that terminated into the ground. During heavy rains the ground would traverse under the garage floor and wick through the block and into the plaster and framing.
I initially thought I would remove the section of damaged plaster, support the framing, remove the damaged section of the sill, replace with new wood, sister the studs with rot at the base, and replace the plaster wall.
I had an idea today to explore structural rot repair using expoxies. If this is possible I could eliminate much of the hassle of this repair. Does anyone have experience or feedback they would share regarding this method?
BTW…I have addressed and repaired the root cause of the leak. This included new drainage and trenching along the wall and parging and sealing the block down to the footer.
  1. Jer | Jan 28, 2007 05:49am | #1
    I have used WoodEpox products with good results. It sounds as if your original solution would be the way to go though.
  2. Jer | Jan 28, 2007 05:50am | #2
    http://www.abatron.com/home002.htm
  3. reinvent | Jan 28, 2007 07:52am | #3
    I second the Abatron
    1. mcf | Jan 28, 2007 04:45pm | #4
      Liquid wood from Abatron looks like the way to go. It has a compressive strength of 5200psi. This is great news. It will save a good amount of money in the budget.
  4. florida | Jan 28, 2007 04:53pm | #5
    I love Abatron epoxy and have used it for years but I'd never use it make a structural repair involving a rotten sill. If you're going to tear the plaster out anyway splicing in a new sill and some studs is no big deal. Do it right with ACQ sills and stainless nails and you'll never have to do it again even if the leak should reoccur.
