stubborn grout haze
fossil | Posted in General Discussion on October 8, 2008 02:57am
I’m not having any luck getting the haze off some porcelain mosaic tiles (1” by 2” rectangles).
The grout is black, the tiles are white. I’ve tried the concentrated grout haze remover with scotch brite scrubber, netting unsatisfactory results. Any advice appreciated, Thanks
  1. FastEddie | Oct 08, 2008 03:41am | #1
    Black is absolutely the worst color to clean up.  Bright red is a close second.  How old is the grout?  should be able to clean it properly after 24 hours.
    1. fossil | Oct 08, 2008 04:47am | #3
      I cleaned most of it off the first day. The next day I wiped more of it off with a dry towel. The next day I tried the grout haze remover.
        Sphere | Oct 08, 2008 05:06am | #4
        Try white vinegar, straight up on a clean sponge.Spheramid Enterprises Architectural Woodworks
        http://www.youtube.com/watch?v=Dj_oEx4-Mc4
        The world of people goes up and
        down and people go up and down with
        their world; warriors have no business
        following the ups and downs of their
        fellow men.
        1. fossil | Oct 08, 2008 05:35pm | #6
          Thanks for the tip. I've got a gallon of it from the mold recipe someone else here mentioned.
          Think a buffing tool on a drill would work, if this doesn't?
            Sphere | Oct 08, 2008 05:59pm | #7
            I don't know. Buffing tool is a broad spectrum term.
            Sponge buffers used on autos with Maguires Mirror Glaze and products like that , that look kinda like egg carton foam , would be about as abrasive as I'd want to try.
            Unlike sanding wood, I'd start with the FINEST abrasive/chemical, and work back wards to what gets it done, then work BACK up to polish. If that makes any sense.Spheramid Enterprises Architectural Woodworks
            fellow men.
          2. fossil | Oct 09, 2008 02:08am | #9
            I was envisioning vinegar on the buffing pad as a possibility. I'll try the vinegar first though.
      2. catfish | Oct 08, 2008 08:07am | #5
        There is an orange nylon sponge that is very effective when used with white vinegar.
  2. doitall | Oct 08, 2008 04:27am | #2
    Maybe try VERY diluted muriatic acid?
  3. KenHill3 | Oct 08, 2008 06:06pm | #8
    I have used the 'Zep' brand grout cleaner with success, I think it's weak muriatic. I got a little desperate to clean off the haze on one project, and used Comet cleanser with good results.
  4. maverick | Oct 09, 2008 02:39am | #10
    I once called Laticrete about removing a stubborn haze and the rep there told me to use dishwasher detergent. make a paste out of it and scrub with a scotch brite pad.
    it worked well enough with a lot of elbow grease
    Dinosaur | Oct 09, 2008 03:30am | #11
    Rent a commercial floor buffer from your local tool rental agency, and buff the floor using the green Scotchbrite discs. (White is too fine; black is too coarse.) The abrasive in those discs is too soft to scratch porcelain tile but it will peel that haze right off them in a jiffy. Vaccuum up the dust with your shop vac, damp-mop twice with fresh water, and you're done.
    Dinosaur
    foolish men call Justice....
    1. fossil | Oct 09, 2008 07:09am | #12
      I'll have to give these all a try, starting with the simplest . Thanks for the tips,
A New Approach to Foundations
