stucco
haldi | Posted in Construction Techniques on October 5, 2004 05:18am
Who has a formula for stucco? are the scratch, brown and finish coats the same mix?
I have done patch jobs before, and always went 1 part portland – 3 parts sand. Today someone asked me “what about the lime?”
anyone?
also should I use the metal edges against the brickmolding on the windows, or just mud right to the trim?
  1. JerBear | Oct 05, 2004 05:31am | #1
    Use the metal edges. Never let masonry touch trimwork if you can at all help it.  One portland, one lime, and 3 sand is a good mix.  Depending on the sand you will have different finishes with the stucco.  Playsand or a finer sand should be used for finish coat.  There is a stucco final coat premix that you can get at a good masonry supply store, it's very fine.
  2. Catskinner | Oct 05, 2004 05:42am | #2
    All of the industry publications I've read say no more than 20% lime. I don't know why.
    I find that about 48 to 50 shovels sand, and 9 shovels of lime to one sack Portland gives a good mix.
    The advantage to lime is it makes a stickier, smoother stucco (easier to apply) with more flexural strength.
    The downside is that lime makes a softer stucco. If that doesn't bother you, then it's not a problem. Fact is, once upon a time a servicable exterior plaster was made of nothing but lime, water, and sand.
    And sometimes cactus juice. <G>
    [edited to comment on sand]
    Sand is a very important and often overlooked component. I use only washed ASTM plaster sand. This is a clean, sharp sand of a specific size. Too much fines in the sand will mess up your water ratio and weaken the stucco, and even cause cracking. Likewise for dirt (silt, clay, contamination). Also, salts and other kinds of contamination can cause a bloom to apear on the surface of the stucco.
    DRC
    Edited 10/4/2004 10:47 pm ET by Dave Crosby
How Trump's “Big Beautiful Bill” Will Affect the Inflation Reduction Act
The Big Beautiful Bill could do away with much of the Inflation Reduction Act, including the 25C, 25D and 45L tax credits.
