I am insulating a foundation wall on an old house by using rigid foam sheathing from frost line to bottom of siding (siding sticks past foundation enough to fit 1†of sheathing). I would like to finish the above grade portion of the foam sheathing with stucco. How should I apply this stucco? Should wire mesh be applied first and nailed through sheathing into foundation wall? Any other suggestions?
Newer pressure treatments don't offer the same rot and decay resistance. Follow these simple strategies to give outdoor lumber its best chance of survival.
