In order to remove the tile floor from a bathroom i have removed the toilet. Problem is i can’t get the ring loose from the copper waste pipe. It’s accessible from below and i see a beautiful green ring of corrosion where the pipe meets what appears to be a brass fitting. Any ideas for freeing these two?
This centuries-old paint offers vapor-permeabiity, maintainability, and longevity with zero VOCs, but know its limitations before you get to work.
What have you tried? It sounds like a soldered joint. Have you heated it hot enough to melt solder on both the inside and outside? Bolt some kind of lever onto the flange so you can put some torque on the joint when it's hot.
Is the vertical run long enough for a coupling? Cut it off with a sawzall.
Not exactly sure of your dilemma....Is the waste line PVC or cast iron? I dont think I've ever seen a copper waste line...Why do you want to remove the ring? Because of the corrosion you see? What I've done in the past is cut the waste line with a saw zall and reattach a new elbow. If you want to run PVC to cast you can use a rubber coupling with clamps...Be more specific.
Good luck
Namaste
Andy
It's not who's right, it's who's left ~ http://CLIFFORDRENOVATIONS.COM
Edited 12/3/2002 7:34:03 PM ET by Andy Clifford(Andybuildz)
He's trying to get the tile from under the ring to do a thorough job.
It's soldered. Heat it up..
"The first rule is to keep an untroubled spirit.
The second is to look things in the face and know them for what they are."
--Marcus Aurelius
For what it is worth my parents place in the mountains of Colorado -- built 1963 -- has 4 inch and smaller copper waste lines. And it is on a spetic system, no building codes in the area at the time of construction. That is just what they used there. We paid $ 0.07 a board foot for pine back then too. No help with the current problem just some unrelated data.
Deblacksmith
Thanks for your thoughts on the stuck waste pipe. But i kid you not, the waste pipe is indeed copper -- heck the whole house is run with copper as i imagine are the other 900 some houses in the neighborhood. Cutting sounds like the simplest course of action since i have clear access from the bottom. But this might interest you since you seem mildly amazed with the copper waste pipe. The fitting is not soldered onto the pipe. Instead the plumber appears to have run the pipe about 1/2" above the ring then snipped 1/2" relief cuts around the entire pipe down to the fitting. The snips are then bent back to the face of the fitting. That's it. No sealant, no solder. The shower is finished the same way (though at some point someone spread some silicone around the copper snips). Signs of leakage are evident from below but nothing like what i'd expect without sealing those joins. Oh well, you see something new everyday, huh.
