Stud finders?
| Posted in General Discussion on March 29, 2001 03:56am
What are your recommendations for stud finders. Wood studs behind drywall, is the current need. I got one of those $20 Zircon (sp?) ones about 3 or 4 years ago but it doesn’t seem to work very well.
Sorry if this a repeat thread. I searched but didn’t find much. I know I scanned an article recently – FHB? JLC?
  1. Adrian_Wilson | Aug 26, 1999 06:23am | #1
    I'm interested in this too: anyone have one of those newfangled ones that find copper, rebar, live wires, etc.?
    1. Matt_G. | Aug 26, 1999 06:33am | #2
      *Adrain:I did find the article - JLC, 10/98. It covers the multi-functioned ones too.I'm probably going to buy one tomorrow and just don't want to end up with a piece of c*#p.
      1. FredB | Aug 26, 1999 07:07am | #3
        *Well share your findings! I am using a Zircon with "deep penetration". It "finds" a stud on one pass. Then on the next pass it can't find it. Instead it finds a DWV pipe. So, it isn't exactly useless, but nearly so.
        1. Matt_G. | Aug 26, 1999 07:25am | #4
          *Fred:Do you know what model of Zircon you have? How old is it? Zircon was the brand that JLC liked the best. I gotta think that technology has improved with these things, but if I'm just going to piss away $20 or $30 I can think of some better things to use it on.
          1. chuck_a_crawford | Aug 26, 1999 08:49am | #5
            *Matt ' I just replaced my old Zircon [ they dont take a fall from the top of a 6' ladder ] with a new Zircon with deepscan . It was around twenty bucks , not the one that locates elect. or steel . It works pretty well on standard 1/2" or 5/8" drywall , though it occasionally indicates something kinda strange , but without tearing off the drywall , who knows maybe it's telling the truth . At the very least it will get you in the vicinity and you can use the old finish nail trick to verify [ assuming it will be covered by what you needed to find the stud for in the first place ] . For me it is worth the price , one plus , the battery lasts forever . Chuck
          2. jim_"crazy_legs"_blodg | Aug 26, 1999 09:13am | #6
            *Yeh, I got one of those Zircon's too. 8 or 10 years old. The switch is kinda funny on mine, but once you are sure it is "on" it seems to work fine. Man, I miss a couple nights and you guys are lightin' the place up! - jb
          3. Matt_G. | Aug 27, 1999 04:52am | #7
            *OK,I bought the Zircon tri scan today - has 3 modes - regular, deep scan, and metal. Seemed to work OK, but nothing to write home about... maybe I should read the instructions - last resort ;^). It beeps - which my old one did not. About 35 bucks.
          4. jim_"crazy_legs"_blodg | Aug 27, 1999 09:52am | #8
            *It beeps? Does that mean you pushin' it backwards or somethin'? - jb
          5. FredB | Aug 27, 1999 10:42am | #9
            *Can't remember what the model number is for mine but it is 2 or 3 years old. I had one of the old ones that broke and the new one with the deepscan was all the rage in the magazines.It frequently gives different readings over the same section of wall on sequential passes. Never really used it a lot because I mainly do new construction until this remodel. It sometimes gets me in the general vicinity and sometimes would get me in big trouble if I believed it was as accurate as advertised.Since I have a fair amount of remodeling yet to do a good studfinder would really be great. How about the new Stanley graphic that is advertised? Anybody with experience?
          6. Mongo_ | Aug 27, 1999 08:50pm | #10
            *I also have the basic Zircon w "deep sensor" capabilities. Bought it about 3 years ago for around $18USD.Works fine for me through 5/8ths drywall. I had a worker get nowhere with it, after watching him he was pressing the button prior to having it set against the wall. May sound obvious, but make sure you've got it placed in the wall, then press the button.I usually run it back and forth a few times, the reading come out within 1/8th inch of each other.I'm considering the newer multi-sensing ones, maybe when this one dies...
          7. chuck_a_crawford | Aug 27, 1999 11:10pm | #11
            *Mongo I have the same problem . My sensor works fine for me but others have problems , guess it takes getting used to . In addition to placing it on the wall before pushing the button , you arent supposed to put your other hand near it while moving across the wall . Since it senses changes in density if you happen to start with it on a stud it will act weird too . Chuck
          8. Joe_Fusco_ | Aug 27, 1999 11:44pm | #12
            *Matt G.
            Hammer & nail? I have on of those Zircons. . .like the one you bought, still use the hammer & nail though. . .
            Joseph FuscoView Image
          9. andrew_d | Aug 30, 1999 05:56am | #13
            *I have the Zircon/deep scan and it works ok -- the trick is using it with a bit of thought about what's in the wall. It's really important to start it against a hollow part of the wall, that's when it calibrates itself. We have plaster walls with buttonboard, and the buttons drive the thing nuts; but because it has a multi-led readout you can distinguish somewhat between studs and near misses.With drywall, tapping the wall is often enough. A bit of insight I read somewhere: look for a nearby electrical receptacle. Because most electricians are right-handed, the stud will be on the left. Measure from there, use the Zircon to double-check the framer's accuracy. (If the stud's not to the left, it's to the right.)The $20 was worth it if only because my 3 y.o. absolutely adores the thing.
          10. Jerry_Hill | Sep 08, 1999 07:13am | #14
            *Stud finders,I've had several different brands .....never had much luck with any of them.Seems like every time I get anywhere near the darn things they wood start beeping.
          11. andrew_d | Sep 08, 1999 07:47am | #15
            *That's the "defect" warning.
          12. jim_"crazy_legs"_blodg | Sep 09, 1999 05:39pm | #16
            *...is it possible you have a metal plate in your head?
          13. Mad_Dog | Sep 09, 1999 08:48pm | #17
            *Maybe it's a quality control issue. Mine (Zircon with the deep scan) works pretty well. Borrowed one on jobsite last year, same model, and it lit up and sounded like a video game. Very unreliable. Maybe the 6' ladder theory?crazy legs-I liked the "beeping backwards" thing/plate in head suggestions. Keep em coming,Dogxxxxxx
          14. CaseyR_ | Sep 17, 1999 06:14am | #18
            *I also have one of the 20 buck Zircons and it usually gets me in the ballpark to finish off with the old "finishing nail trick" mentioned above. It occasionally goes a little crazy, but then so does my cat. However, what I really need is a chick finder that works...
          15. jim_"crazy_legs"_blodg | Sep 17, 1999 09:43am | #19
            *Well Casey, man, you aren't too far from JonC, and that guy is a chick MAGNET. If you started runnin' with him, you would have to benefit just from the overflow. - jb
          16. J_RAMEY | Oct 11, 1999 06:57am | #20
            *Matt GI found the best for finding studs is a cilinder cow magnet. It will locate the nail on wooden studs and metal studs also. It's cheap, and you don't have to worry about breaking it. When I first saw it my boss was using it to locate studs. Low and behold, he found them faster then my twenty dollar finder did. Sense then my "high dollar" finder stays in my tool box, and my Magnet stays with me. Hi-tech has its places. But the cow magnet is the best for this problem.Jason
          17. FredB | Oct 12, 1999 11:38am | #21
            *OK, I give, just what is a "cilinder cow magnet"? Or, did I just bite on a joke?
          18. Matt_G. | Oct 13, 1999 04:05am | #22
            *Something that sticks on the fridge door???? My best guess????By the way, maybe I shoulda read the instructions for the new stud finder for more than 20 seconds, but, for now, my best method is rapping knuckles on drywall.
          19. CHARLES_CHRISTENSEN | Oct 13, 1999 08:50pm | #23
            *If I recall correctly a "cow magnet" is a magnet that you force down the throat of a cow. The idea is to collect any loose iron or steel objects that the cow may have ingested.I believe that the collection is then expelled in the usual way but whether the magnet is retrieved for repeat use is an area where I have no experience nor do I wish gain that experience.If you are trying to find nails with a magnet have you tried those rare-earth magnets? I just bought six of them out of one of the woodworking catalogs. They are the size of a quarter and I think they are permanently stuck to my refrigerator. They brought to mind that fifties SI-FI flick "MAGNETIC MONSTER".
          20. J_RAMEY | Oct 14, 1999 05:59am | #24
            *Sorry Fred,I admit it. I can not spell very well. It is a cow magnet. I just tape some string on it to find the nails or studs.sorryJason
          21. jim_"crazy_legs"_blodg | Oct 14, 1999 09:04am | #25
            *Rare Earth was a pretty good live band. - jb
          22. FredB | Oct 15, 1999 02:35am | #26
            *Jason:I wasn't picking on your spelling, heaven knows I have my own problems there. I just don't know what a cow magnet is, cylinderical or any other shape.
          23. Bill_Brennen | May 16, 2000 05:40am | #27
            *Time to revive this old thread. Maybe the new milennium has spawned a superior electronic stud finder (or babe magnet?). I use rare earth magnets that are cylinders 1/4" high by 3/8" diameter. They not only find the nails/screws in drywall, but they stay there until you move them, even on ceilings unless popcorned. They cost me $5 each many years ago, are probably less now. One might try Edmund Scientific. I keep two of these together in a film can. The one with all the tools clinging to it!The cow magnet is designed to stay in the cow for its whole life. The idea is to keep the barbed steel objects in the beast's tough stomach where they will do no harm, rather than letting them pass to the tender intestines which could be ripped open. Yecch!The magnets are not any good for walls with thick plaster, or for framing the rockers did not fasten to. Or floors. I bought the $20 Zircon, and it was inconsistent, to say the least. I read all the directions, did a repeat test on one place, got a bunch of readings, and returned it for credit. If I am going to guess, I can do it freehand without a yellow box to help me. However, hope springs eternal in the tool-lover's heart. Has anyone had unequivocal success with one of these gizmos? What we need is a form of x-ray glasses like in the old comic books so we need not depend on LED's and beeps to tell us where the framing is! Guys who do a lot of remodel work would pay a lot for one that did that. Hundreds, not thousands.Bill
          24. Ed_W | May 17, 2000 07:00pm | #28
            *I too returned my Zircon after I called them and was told that they will not work with plaster walls. Would have been nice of them to indicate that on the package. went back to the finish nail and hammer.
          25. andrew_d | May 18, 2000 07:01am | #29
            *I have one and do use it with plaster with "deep scan", but only as one trick among several. Someone said the $$ Zircon "videoscanner" worked well. Whatever.
          26. Frank_"Mad_Dog"_Maglin | May 18, 2000 12:20pm | #30
            *Hey Andrew, Do you consider the Zircon a toy?
          27. andrew_d | May 19, 2000 08:37am | #31
            *Uh-oh -- trick question. FWIW, my 3-y.o. son loved it!I usually can find the studs faster without "Zircon prospecting". And it's just not neat enough to be a toy. Now, a PL5 laser...
          28. jim_"crazy_legs"_blodg | May 19, 2000 02:36pm | #32
            *...you can find studs with a laser?
          29. andrew_d | May 21, 2000 05:01am | #33
            *Yeah, I bought one cheap surplus from Ronnie's "Star Wars" program!
          30. Jamie_Richard | Jul 16, 2000 08:10am | #34
            *You probably have a new stud finder by now. I just bought one that supposedly finds wood, metal, and live wires. It sounded so good at the store. I had an old one that just found the studs and I liked it much better than the new one with all the new features. In this case, KISS (keep it simple stupid) seems to be the best idea. What I do is find the layout (usually 16'' on center), find a stud, then just use my tape to locate the other studs.
          31. BIG_F | Jul 22, 2000 12:36am | #35
            *The second knuckle of the middle finger on my right hand works exceptionally well but on the days it lets me down, I've always got the left hand in reserve. As a last resort measure off the side of an electrical box and check with hammer and finish nail!
          32. TomMo | Sep 19, 2000 07:52pm | #36
            *I bought the new version of the Zircon Videoscanner (version 5.5). It was not worth much on plaster walls until I 1)Read the directions, 2)"Initialized" the scanner on the wall, and 3)Went slow enough for the scanner to do the work. At one point I thought it went crazy telling me there was power in the wall where there shouldn't have been any. "Zeke" was right, I was wrong. I'm glad I opened the wall carefully! It also located a metal plate that was put there for some unknown reason. I also found the little GB "pencil" hot wire detector to be really helpful in tight places, it ACCURATELY followed the wire through the wall.
          33. Mr._Pita | Sep 19, 2000 08:08pm | #37
            *Amen on the GB tool. I have one from GB, and one from Greenlee that cost twice as much. I love the GB - much easier, more accurate, battery compartment doesn't keep popping out, etc.
          34. Little_Joe | Sep 20, 2000 05:31am | #38
            *TomMo & Mr. Pita -- This GB unit sounds like what I've been looking for. Either of you know the depth range of this little puppy? How much does the price tag say? If they're really worth it, there's a couple of places I can look for one locally.Thanks. LJ
          35. Mr._Pita | Sep 20, 2000 03:42pm | #39
            *It cost me $10 at HD. GB calls it the "Circuit Finder". Greenlee calls theirs "AC Detective". I've been able to use the GB with old pre-romex wires in plaster walls. It just senses the (I'm guessing) magnetic field generated by the electric current. I don't know what the maximum depth is, other than as a DIY, it has found everything I needed or asked of it. For example, I know it'll work in 1-1/2" of plaster (with wires say 2" beyond in the stud pocket) but maybe, maybe not 4" of concrete - never tried. I also don't know if it'll work with wires in conduit. In open air, it'll work to a distance of say 12-18" from the wires. It works like 3 feet from flourescent bulbs in my shop, too, so it is possible to get tricked with false readings. Greenlee does have another tool, "Pocket Volt Tick", which may be more similar to the GB and more effective than their other one. I dunno, but GB=Great Buy. I use it to: determine if live wires are behind a wall I'm going to puncture/demo/etc., follow live circuit to the next outlet, etc. The thing can/will get tricked by wires crossing in the wall, but with trial & error/guesstimation, and switching off other circuits, I'm able to get by. http://www.gardnerbender.com/ http://greenlee.textron.com/
          36. JaW | Sep 27, 2000 12:45am | #40
            *Has anyone used a metal detector to check gas lines or re-bars? How practical is that? How much does it cost? What else do you use? Any test and true method?
          37. Berserker | Oct 26, 2000 07:08pm | #41
            *I had a Zircon 4.0 for about 6 months, and after the eleventeenth time it lied to me (yes, I changed the battery) it met it's end against an elm tree. The electrical box/tapemeasure method has served me well since then.
          38. John_Sprung | Nov 11, 2000 04:23am | #42
            *Over 30 years ago, I had a little gadget called a "Morrison Probe". It consisted of a piece of small tubing, maybe 1/16" I.D. with a 90 degree bend, maybe 1" radius. One leg went about 1/4" beyond the bend, and the other about an inch up into a plastic triangular piece that had one edge 90 degrees to the tube. There was also about a foot of stiff piano wire with a handle on one end. What you'd do with this is make a small hole thru the lath and plaster, insert the tube using the plastic part to orient the tube to point horizontally towards where a stud should be, and then shove in the piano wire until it hit the stud. Pull it out without moving the wire, lay it against the wall with the tube over the hole, and the wire shows exactly where the stud is, with only one small hole to patch. I think it was in a toolbox that got stolen. There are times when I wish I still had that thing.One useful trick: If you have any reason at all to pull the baseboard, do your exploratory holes between the top of the baseboard and the top of the sole plate. I shove some spackle in them afterwards on general principles, but I don't bother trying to make them look nice.Another trick: Wrap a clean rag around an old electric shaver and rub it against the wall in question. Listen for the change from hollow to solid sound. The stud finders do basically that, only at higher frequencies that we can't hear, and their electronic listening is more easily confused than ours.-- J.S.
          39. Bill_Brennen | Nov 12, 2000 06:42am | #43
            *John,Thanks for the cool tricks. The probe could be made from brake line, couldn't it? (And piano wire, of course.) I wish I'd kept my old Norelco to try that other idea out. The noninvasive methods are just so much faster/easier than holes and patches. Laparoscopy is cool, but ultrasound/x-rays are even more cool.Still hoping for my x-ray glasses to arrive....Bill
          40. Matt_Willahan | Jan 16, 2001 06:41am | #44
            *from 12 years I never use stud finders,, its a big joke for an expert workman,,, I use tights finger and knocking on wall you can feel the hollow,, so theres no studs,,, once you knock on wall with tight hollow,, and your head is "beep beep" you found a stud then simple mark it,, and lay out on 16 inch on center, or 24 inch on center once the next stud you were marked out,,, knock it to make sure,,,,, instead of waste time walking to the tool box and grab a star wars toy :)
          41. charlesaf3_ | Feb 07, 2001 03:32am | #45
            *What about those of us living in/ working on houses built before 16 oc was invented? The studs, joists etc. in my house (built in 1862) range from 10 oc to 20 oc, in no particular pattern.And unfortunately I haven't been happy with my zircon.
          42. Doug_Anderson | Feb 11, 2001 07:13am | #46
            *C'mon, you guys, can you actually get these things to work? Every time I try to use one, it just points to me...
          43. JIM_DANIELS | Mar 25, 2001 04:57pm | #47
            *TRY THIS. A CYLINDER SHAPED MAGNET SLID INTO A LENGTH OF SURGICAL TUBING. RUN IT ALONG THE WALL UNTIL IT HITS A NAIL OR SCREW THEN LAYOUT FROM THERE. ALSO GOOD FOR PICKING UP SCREWS ETC. YOU CAN GET THE MAGNET AT A FEED STORE FOR ABOUT $3.00 PULL THE TUBING OFF YOUR WIFES OLD EXERCISE MACHINE.
          44. Tim_Mooney | Mar 25, 2001 08:45pm | #48
            *Do I have the only zicron that works????? Hold steady pressure.Move slowly. no plaster.
          45. dave_Race | Mar 29, 2001 03:56am | #49
            *16 z. estwing - tuned ear-works every time!
  2. Matt_G. | Mar 29, 2001 03:56am | #50
    What are your recommendations for stud finders. Wood studs behind drywall, is the current need. I got one of those $20 Zircon (sp?) ones about 3 or 4 years ago but it doesn't seem to work very well.
    Sorry if this a repeat thread. I searched but didn't find much. I know I scanned an article recently - FHB? JLC?
  3. chistophe777 | Apr 02, 2013 12:32am | #51
    stud finders
    I have found that the best stud finder is a strong earth magnet disc about 1" in diameter screwed onto a block of wood using one of the available mounts with a counter sunk screw hole. This will allow you to quickly locate one of the many drywall screws that have been driven into the stud walls. Its also a great way to quickly locate and remove the majority of drywall screws before tearing down a boarded wall. Sometimes, I have removed all the screws on a large section of drywall, swung it open on the wall, insulated behind it and then simply swung it back into place and rescrew the wall board. No mess, No waste, and no trips to the building supply store.
Mortar for Old Masonry
