stupid question time again.- soffits
i need to build an interior soffit(?) in the kitchen to cove a 2 inch pipe. Thinking about 2×4 fastern flat and then cover with 3/4 plywood that I have to get the drywall clearance. or do I rip the 2x down?
I been putting it off due to I was going build a upper cabinet with fake back. scratch that plan
( this is old picture but you can see the pipe at top of wall)
If all you have to cover is that one piece of vertical pipe I would just cut the back out of my cabinet. Easy enough to box around inside the cabinet.
that is what I was planning on doing but DW decided that there will be no upper cabinets.
Did you explain that this will be
a change order and will cost extra?
If there are no uppers as the wife wants then do as Dino suggested, I'd opt for the 2 X 2.
Happy Birthday! Not possible to reroute the pipe?
thats the outside wall at the gable. there is a concrete wall with a truss sitting on top. that pipe is the vent for the kitchen sink. its one of those "oh, $@#%" that you dont see till you do it.
Coffered Ceiling. You're up to the task.
Hmmm, chance to be creative. How about running a wire to that location? Build a box to encase the pipe and mount a light on it, balance it with one on the other side of the window.
You gonna run this 'soffit' the whole length of that wall-ceiling corner so it looks like it's there on purpose?
Save yourself lotsa time and trouble; frame it like you said with flat 2x (or rip 2x4 down to 2x2's and double your stock), but don't gyprock it. Get some 5/16 x 3½ pine beadboard or vee-joint or whatever you fancy, and nail that on right over the frame, horizontal or vertical as looks best. No corner joints to tape and mud; just nail on 9/16" cove moulding. Pre-stain the stuff to match the rest of the woodwork.
Done.
Dinosaur
foolish men call Justice....
