Planning to remove current flooring (vinyl tiles & carpet) which is on a 50 yr old concrete slab and replace it with a radiant floor heating system and ceramic tile. What type of moisture barrier should I use to prevent the moisture that seeps up through the concrete floor from being absorbed by the new wood sub floor that will hold the radiant tubing in place? Never had water come up only dampness.
