substrate for tile countertop in den?
| Posted in Construction Techniques on October 26, 2002 03:52am
I am replacing an old countertop in my den with a tile countertop.  Since there is no water problems, what substrate should I use?  I need it to be pretty strong because i am going to build some book shelves and stack them on top of the counter.
  1. jet | Oct 26, 2002 07:42am | #1
    If you don't care about the thickness, try 2 layers of 3/4 plywood then tile over that. Set the tile back from the edge by the grout line distance and cover the edge of the plywood with a hard wood molding or bullnose. varnish then grout the tiles.
    Good luck.
  2. brianspages | Oct 26, 2002 08:20am | #2
    consider placing your bookshelves on your tile substrate and fastening (ie. built-in) before tiling or wall mounting, using a cleat under your shelves and fasten with structural screws and cup washers to carry the weight.  support of weight seems to be your rationale for setting bookshelves on counters.  then it seems like you want to take them with you when you leave???
    brian
