I am interested in having an open floor plan in a section of the house and within the area some concrete floors abutting soft or hardwood flooring. I want the concrete floor to be at the finished height of the flooring, (no stepping up or down), but am unsure of expansion of the flooring material. Any suggesions.
location?
concrete expansion?
wood floor shrinkage/expansion most likely?
stamped concrete will provide some control joints within the concrete floors themselves.
various form/screed combos can provide a step.
could attach material at flooring thickness under your screed. use rough lumber for your forms to leave ~3 1/2" slab under wood floor area. leave the earth under the concrete floor areas elevated that much higher.
could simply add 2x on side under screed, determine the difference between 1 1/2" and your wood floor thickness and make that up with ply subfloor or insulation material if desired/necessary.
my guess is that you're most concerned about problems at the interface...
brian
*Wood flooring should not expand enought in height to matter.Softwood flooring will compress after a few expansion/contraction cycles if set tight. So spacing is not as much of a problem as with hardwood.1/4" expansion in 10' (width) is about as much as a hardwood will expand. If it expands more than that it will pull the nails out.
*I'd normally allow 3/8" (10mm) expansion gap at the perimeter of a hardwood floor and fill with a compressible filler.As George said, the vertical expansion will be negligible.
*Let's back up here a second. On top of what substrate are you pouring a concrete floor ? How thick will the concrete be ?
