Sump pump drain
Stogman | Posted in General Discussion on May 8, 2006 04:09am
OK, I am looking for information on the best way to run my sump pump line.  Right now I have a 2″ PVC pipe stubbed to the outside.  I would like to tie it into my drain tile that I have burried for my down spouts.  Can I just 90 degree it and run a pvc pipe into the ground and hook into the tile?  Do I need to incorporate a clean out?
all suggeestions are welcome
thanks
  1. DanH | May 08, 2006 04:21am | #1
    Not sure what the legal requirements are, but you need a cleanout somewhere on the tile line, and there should be some sort of a vent/overflow where the pump line enters the tile so that if the tile is clogged you will notice it (due to water spewing out of the vent) and the pump won't just sit there and spin without pumping anything.
