Hi everyone. I have a sump pump that hooks up with 3 feet of corrugated hose to a vertial drain pipe (1 1/2″) that goes to the ceiling ,up and over a heating plenum then down again about 2 feet, a 90 degree turn then out the wall. When it shuts off , the check valve hammers like crazy. Does anyone know if the more expensive check valves work better or should I put a second check valve near the ceiling. Any suggestions? Thank you.
Is it the check valve per se, or the pipe banging against the heating duct? Bracing the pipe so it doesn't touch the duct may make a significant difference.
Hi Dan . It is definitely the check valve.
If it's a metal (commercial-type) it will be very noisy. PVC with rubber/plastic flapper is much quieter. Sometimes you can help with pipe clamps/mounting method that is more resilient.
Sump Pump Hammering
Hello All,
I use a pvc swing check valve on our sump pump. There is some water hammer going on with the valve.
Pipes are all mounted walls and not vibrating or moving.
Would a ball check valve or spring check valve reduce the water hammer ?
Any input would be appreciated.
Thanks.
Dan
You mean just a "clunk" when
You mean just a "clunk" when the pump stops, or some sort of continuous sound?
sump pump hammering
Just a clunk from the flapper check valve when the pump stops.
Wondering if a ball or spring check valve will not make the clunk noise.
Thanks.
Where exactly is the check valve?
Sump Pump Hammering
Check valve is screwed directly to the sump pump.
There is no piping between the pump and check valve.
There is about 14' of PVC from the check valve to the outside.
Thanks.
My impression (from just a few examples) is that the flapper style valves are a bit noisier on closing. But they have the advantage of allowing more flow, and thus likely make the pump slightly quieter in operation.
Gotta wonder why it's important, though. If screwed into the pump the valve should be inside the pit and most noise would be contained within.
Check valve is in sump pit which is covered so hammering/clunk noise when pump stops is minimized.
Just wanted to determine if is possible to further reduce clunk when pump stops.
Thanks for info.
I can't say for certain, but an air bladder might help absorb some of the shock.
I wonder if you moved the check valve so it's farther away from the pump if that would help. That way you wouldn't have a vertical column of water backing up against it.
I'd say it's not broke -- why fix it? Moving the valve upward would move it out of the pit and likely result in MORE noise.
