“Sump pumps – battery back-up”
| Posted in General Discussion on October 21, 2003 11:22am
I got a quote from a sub to install a battery back up sump pump.  Wondering if anyone has any expereince with the different types/brands and what this should cost.  Quote to me was about $900 in Central Indiana.  I am wanting to justify cost to my client.  I figure there is $300-400 in materials (12V pump, battery, charger).  Does this seem about right?
Paul, Indianapolis
  1. OneofmanyBobs | Oct 22, 2003 01:36am | #1
    Last I looked, a small pump with battery and charger was around $200.  PIpe and fittings shouldn't be much.  Make sure you and the customer approve of the pump and run time.  The ones I've seen don't have a great pumping rate and only go 8 hours.  I lost power for days after the hurricane and got flooded 3 times.  Looked into getting a battery system but decided against it because of the short run time.   Also, my big 1/2 HP pump can easily get swamped in a heavy storm and a little 150 GPH pump won't do much for me.  I don't know if you can get big battery pumps or what they cost, but that's what I'd need.  I've seen the small ones at several places, but never any big ones.
Podcast Episode 691: Replacing Vinyl Siding, Sloping Concrete, and Flat vs. Pitched Roofs
Listeners write in about ground-source heat pumps and weatherstripping and ask questions about engineered siding, concrete that slopes the wrong way, and why houses have pitched roofs.
  • A Postwar Comeback
