Sunlight “pipe”
spclark | Posted in General Discussion on March 8, 2014 07:25am
Moved into new house (built late 70’s pre-fab) last Nov., main bath has no window as it has no exterior wall. Wife mentioned skylight as possible solution (had Velux fixed and openable before) so I suggested the circular skylight “pipes” available now in 10″ or 14″ diameter as maybe easier installation & better weather resistance while still adding illumination during daylight hours.
I know Velux makes somthing in this line, other brands likely too. Looking for + / – opinions on product selection, ease of installation (experienced DIY’er here), maintenance considerations down the road.
I’d consider headering off a roof joist if I thought installing a > 15″ wide skylight would be preferable but then I’d have to move the bathroom’s fan & duct work, frame & drywall a ‘tunnel’ from ceiling to roof sheathing… vastly more work than a 10″ pipe would require.
Comments & suggestions invited please!
  1. ronbudgell | Mar 09, 2014 08:04am | #1
    They work really well. The light is diffused, not direct and it's surprising how much light they can provide.
    Installation can take as little as three hours if you get lucky. I have never spent more than five hours on one, counting the time from arrival on site with all the right tools and materials on hand. Be very careful with the location and layout in order to avoid having to do any structural work and get the light location right inside.
    The condition of the roof makes a big difference to the install time. The easiest situation is with an asphalt shingled roof in good shape so the new flashing can be woven into it without a struggle.
    I think a skylight in a bathroom is almost always a bad idea, especially in a cold climate. Condensation is nearly always a problem. Drywall in the well deteriorates fast.
    Ron
  2. user-2452626 | Mar 09, 2014 04:16pm | #2
    Velux Sun Tunnels
    I had the exact same situationist in my home for many years. I installed 2 10 inch Velux sun tunnels in my bathroom this past summer.  They work great!  The install was not that difficult at all. Much easier than going the skylight route...and much cheaper.  I would definitely recommend this product. I've attached a picture so u can c how they look. I'm currently in the process of completely remodeling this bathroom.
    1. DanH | Mar 09, 2014 05:53pm | #3
      Kinda odd having them installed in the floor like that, though.
      spclark | Mar 09, 2014 05:57pm | #4
      Short Run
      from BR ceiling to roof penetration's (relatively) easy to adapt the connecting tube for I'd assume?
      Various kit lengths I've seen described of around 48 - 52" but though I haven't measured anything just yet my need is for ~ 34 - 36" I think. Never having seen one I'd guess there's either two telescoping portions, one of which could be cut down as necessary?
      There also appears to be an adjustment feature (not unlike round ductwork elbows) at one or both ends to facilitate eccentric aligmment of the ends?
      I'm no stranger to sheet metal work but admit this is a product that's new to me.
FHB Podcast Segment: Patching Drywall Near a Shower
Learn how to patch drywall above a fiberglass shower without totally redoing everything.
