Where do you purchase prefab sunroom panels similar to the ones that are advertised on TV as packages? I’ve searched and can’t seem to find them anywhere. There are plenty of companies that add on rooms as you know but I would like to have my crew install them and enjoy the profit from the labor charge myself. If a string on the subject exists please link me. Just a note; I’m located in the Nashville, TN area so something close would be better.
Greg
I am a dealer , not in yuor area, not trying to sell you and not going to mentin brand names so this is not a self serving sales call
ask a dealer in your area if they will sell direct to contractors. we do at substantial savings. we will work with a contractor and help them with the first one or two and then they take it from there. so not only will you make it on labor but make some on the kit as well
think about becoming a dealer, check the web for differnet companies, but dont go the cheap route, cheap means leaks
if you are going to go the cheap route then your workmanship can be less then perfect because those cheap ones dont rely on good condtructino, they rely on silicone, aluminum "spacer panels " that can be cut(out of square), short warranties and short term dealerships
also some of the units are starting to have trouble in some ares due to the inefficiency of all the glass , sheer and lateral loads, lift and have to get built as a "non-conforming" addition
many also rely on no permits being pulled. units being "snuk in" on a back yard patio or deck. then when they fail the small prnt in the warranty says send copy of final building permit or a letter from yur local authority stating no permit was needed.
the cheapos are really hurting the good sunrooms reputations
Hey and big tip..........you cant run a double pain glass unit through the table saw to make it fit to compensate for other shoddy work
quality sunrooms rely on good craftsmasnhip from start to finish and some warranty for life , some for 20 years
sunrooms are only part of what we do, and it can be a nice niche and supplement for many generals out there
