Sunroom Windows
| Posted in General Discussion on May 1, 2002 07:49am
I’m about to start constructing a sunroom/screened porch.  I’d like to use it for all four seasons.  My plan is to use large double hung windows.  In the winter I’ll use the sash without the screens.  During the warmer months I’d like to remove the sash and just use the screens.  Removing the sash should give me move air movement than simply opening the windows.
I don’t want to use casements because I’m afraid having them cranked open for 8 months could water damage the mechinism (sp?) and interior wood trim that would be exposed to the outside.
Does anyone see a reason why using double hungs wouldn’t work?
  1. dollarb2 | May 01, 2002 08:58pm | #1
    Dave,
       I've got Certain-Teed (sp?) brand double hung, double insulated, Xenon filled, Thermoflect and use them in the same way. They are pricey but IMHO they're worth every penny.
    $ Bill
    BossHog | May 01, 2002 09:01pm | #2
    Why wouldn't you want to be able to shut the windows when it rained? If your double hungs are big enough, just leave the bottom sashes open most of the time. Then they'll be there when you want to shut them during ####storm.
    Redneck Extraordinaire
    1. DaveArbor | May 02, 2002 03:51pm | #5
      Boss,
      Thanks for the response.  To answer your question about the sunroom windows, I'm in the Southeast and I don't think I'll get enough airflow if I leave in the windows during the summer.
      Dave
      Arbor Homes
  3. PhillGiles | May 02, 2002 12:59am | #3
    My parents had a scratch-built sunroom, they did it the same way you do a cottage: large windows that hinge from the top and swing all the way to the ceiling where they're held by large hooks and eyes. The pins in the hinges could be pulled if you wanted to take the windows completely out
    Phill Giles
    The Unionville Woodwright
    Unionville, Ontario
  4. djmarro | May 02, 2002 03:50am | #4
    Double hungs should work ok for what you describe. I just finished a room like what you are planning. I used vinyl sliding windows. 2- 4' x4', and 2- 5' x 4'. I also used a 2' x 5' casement next to the sliding door. The vinyl windows work slick, hopefully will be low maintenance, and have a large screen area. I also put in a venting roof window to let some air flow. Good luck on your project. I am enjoying mine so far.
        Dana
Mortar for Old Masonry
