supply line for hot water baseboard
pahammer | Posted in Energy, Heating & Insulation on October 31, 2006 09:17am
Can you run supply pipe for hot water baseboard heat through the wall or does it have to come up from the floor?
  1. goldfreaz | Oct 31, 2006 09:41pm | #1
    interior walls are good, but exterior walls may freeze.  This could present problems because  heat usually is wanted on exterior walls...
    Edited 10/31/2006 5:03 pm ET by goldfreaz
  2. cliffy | Nov 01, 2006 02:38am | #2
    I have done it on out side walls a couple of times when there was no where else to go.  I put all the insulation behind it and kept it as close to the warm side as possible.
    Have a good day
    Cliffy
