support framing for overhead garage
mcguire | Posted in Construction Techniques on September 5, 2006 11:06am
A friend in Washington DC lives in an old townhouse on Capitol Hill and is very tired of finding street parking, so plans to convert his rear garden terrace that backs to an alley into a “garage” by installing a conventional 18 foot wide steel overhead door, but of course, he has no support structure.  His desire is simply for “lockable” drive in parking, not an enclosed structure.
Can anyone help me design appropriate framing?
  1. Jamie_Buxton | Sep 05, 2006 11:13pm | #1
    So say this door is open and you get a nice big wet snowfall.   You do get those in DC?  Does the door collapse on to the cars below?
    1. mcguire | Sep 05, 2006 11:38pm | #2
      The door would never be in the horizontal position except opening and closing
        BillHartmann | Sep 06, 2006 05:08am | #8
        I was going to recommend a gate also.But depending on the space he might not have room for a swing gate.But you can get sliding gates also. And operators for them.http://www.amazinggates.com/sliding_gates.html
        Edited 9/5/2006 10:09 pm by BillHartmann
  2. timkline | Sep 05, 2006 11:44pm | #3
    that's just plain weird.
    usually swinging gates are used in this situation.
    do you have a photo  ?
    carpenter in transition
    1. mcguire | Sep 05, 2006 11:54pm | #4
      Do they make some kind of swinging gate that can be electronically opened and shut?
      1. Framer | Sep 06, 2006 12:11am | #6
        "Do they make some kind of swinging gate that can be electronically opened and shut?"Yes, they do. People have them installed in driveways every day. You'll have to find someone near you. That's your best bet. Forget the garage door opening in mid-air thing with no roof above. Sure you can build something but that's nuts. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=300022944275&ssPageName=MERC_VIC_ReBay_Pr4_PcY_BID_IT&refitem=300022319729&itemcount=4&refwidgetloc=closed_view_item&usedrule1=CategoryProximity&refwidgettype=cross_promot_widget#ebayphotohostingJoe Carola
      2. timkline | Sep 06, 2006 04:51am | #7
        http://gatecrafters.webdirectbrands.com/gopage.asp
        http://www.amazinggates.com/automatic_gates.html
        http://jtgateoperators.com/?gclid=CP_fmZ7zl4cCFUo7Ggod2ir-qg
        there's a lot of them out there.
        good luck.
        keep it simple.
  3. FastEddie | Sep 05, 2006 11:55pm | #5
    It doesn't take much to install a garage door.  You need a decent header for the coil spring, and for the door opener to push against.  And some kind of ceiling framing to hang the opener off.  You could build a box of 4x4 or 4x6 posts at 4 corners, two at the face of the garage and two about 10 ft back for the opener.  And then use a exterior grade glulam or similar for the door header and something lighter down the sides.
