Support Question – Attic flooring
royaltigerfan | Posted in Construction Techniques on October 24, 2023 12:43pm
If I wanted to try and remove these supports… 1,2, & 3…
Is this something from an integrity standpoint that the roof needs? It seems like these aren’t supporting much but I am not 100% certain.
You see the header just to the left of the image that should support most of whats being held by those supports? Was curious if these 2×4’s could be removed as I assume they are using during the framing of the house and not really holding much from a structural standpoint. I will have to reroute the duct as well.
Open to thoughts/suggestions.
edit.. can’t get the images to upload to the site properly, lets try this…
https://ibb.co/PrS4TWy
https://ibb.co/3ct9fPY
Thanks.
  1. Deleted | Oct 24, 2023 12:45pm | #1
    “[Deleted]”
    ct_yankee | Oct 24, 2023 07:59pm | #2
    I could comment but not until I see a pic of this area from the outside.
    Also 2 more interior: Put your back against the drywall behind the studs on the left side of this photo, looking toward the lower right (parallel with the ceiling/floor joists).
    Take one pic slightly to left and a 2nd slightly to the right.
    It appears to be a stick-build roof and not trusses so there it's possible that they may be temporary braces installed to frame the roof (which looks a bit complicated).
