Surge protection
edwardh1 | Posted in Energy, Heating & Insulation on August 4, 2006 05:18am
do you use it on microwave ovens and garage door openers?
both are/can be built in and slow to change out
what brand
anyone use Belkin?
  1. paul42 | Aug 04, 2006 04:48pm | #1
    http://www.taunton.com/finehomebuilding/pdf/Lightning.pdf
    one of the better articles I have seen on the subject.
  2. DanH | Aug 04, 2006 06:15pm | #2
    Your standard GDO and microwave opener are cheap enough and fungible enough that specific surge protection for them generally isn't required. If you're in an area/situation where lightning-induced surges on the power lines are likely then you're probably better off spending your money on a "whole house" surge protector.
    Individual surge protectors generally should be installed on high-value items (big screen TVs) and hard-to-replace items (computers) if surges are likely in your area. Also, any connection between phone or cable TV lines and a high-value/hard-to-replace item should have protection. (One spot that can be overlooked is a cable TV modem connected to a home computer network. This can introduce surges onto the home network unless well-protected.)
    And, of course, any outside antenna (or antenna in an attic) should feed through an appropriate lightning arrester.
Townhouse Transformation
A sleek, modern redesign maximizes space and light while preserving the building's historical charm.
