Sweating a vertical copper joint
TWG | Posted in General Discussion on December 8, 2006 07:06am
Is there a trick to sweating a vertical pipe joint?  I have succesfully sweated many joints horizontally but I can’t avoid this one vertical one.
I have done some FHB and internet searches that offered no specific help.
I used emory cloth to get the pipe and fitting ends extremely shinny.  They are dry.  But the solder will not suck up into the joint.  Maybe I’m using to much flux, or not enough.  Are the pre-soldered fittings the answer?
Thanks.
  1. DanH | Dec 08, 2006 07:17pm | #1
    If the joint is clean and properly fluxed and hot enough, capillary action should suck solder up into the joint. It won't work until the joint is hot enough to keep the solder fully fluid as it's sucked into the joint, and won't work if the flux is burned out from overheating before the joint is made.
    Of course, you need to have an opening on the line somewhere (open faucet or valve, or the other end of the pipe simply not connected yet) so that air pressure doesn't build up inside and blow the solder out.
    And of course you can't have water in the lines anywhere near the joint.
    I did have a lot of trouble once with some mis-sized pipe. It wasn't perfectly round but had a slight flat on one side and was overall a bit undersized. You could have the same sort of problem with bad fittings. Since you're relying on capillary action, the space between pipe and fitting needs to be fairly tight (though not so tight that you have to force the pieces together).
    People never lie so much as before an election, during a war, or after a hunt. --Otto von Bismarck
    1. TWG | Dec 08, 2006 07:24pm | #3
      Thanks DanH,
      An out of round fitting may be the answer.  There is a little wiggle in the dry fitting.
      1. DanH | Dec 08, 2006 07:33pm | #4
        If it's poor fit you'll likely notice that the solder wicks into the joint for part of the diamater, but leaves a gap on one side, where the fit is worst. If the solder is just "standing" on the joint and not getting sucked in at all it's either too cold or not properly cleaned and fluxed.
  2. tb1472000 | Dec 08, 2006 07:20pm | #2
    The trick is to ensure the joint is hot enough.  The solder should flow right up into the joint.  I don't find it any different than the joint being horizontal.  Now if there is any water in the pipe, that will cause a problem.  The water doesn't allow the joint to get hot enough.  I've usually found when I have problems soldering copper pipes, it is because there is too much water left in the pipe.
  3. JAlden | Dec 08, 2006 07:50pm | #5
    What kind of torch and tip are you using? It may not be getting hot enough.
    Other than that, Dan has you covered.
  4. gravel | Dec 08, 2006 07:52pm | #6
    I had a similar problem recently and found that just enough water was dripping to keep the joint from heating properly.  My dad told me about an old plumber's trick of stuffing a small piece of bread above the fitting to stop the drips.  Worked like a champ although I did have to clean a few mushy bread remnants from the screen for the faucet.
    1. DougU | Dec 08, 2006 08:12pm | #7
      Gravel
      Thats an old trick that works well but the first rule is you have to take the screen off the faucet! Of course you know that now dont you. :)
      Oh, and dont use bread with the little chunks of grain it it.
  5. TWG | Dec 08, 2006 08:22pm | #8
    The fitting was out of round.  It worked my first attempt with a new fitting.
    This concludes my installation of the new Frig with water line.  Back to the woodshop.
    On a side note, I think those saddle valves that come with the frig water kits are junk.  I could not get it tight enough to keep the washer from dripping.  This led to a regular brass valve instead.
    Thanks everyone for their advice.
  6. MikeHennessy | Dec 08, 2006 08:31pm | #9
    Six steps to soldering vertical joints:
    1) Clean parts, male and female, with emery cloth till they shine like a new penny. I make sure to get the edges of the female fitting cleaned as well, but not everyone does.
    2) Apply flux to both parts, coating all mating surfaces.
    (Optional for problematic joints -- tin the male fitting by heating it, fully coating the mating surface with solder and, while it's still molten, immediately wipe clean with a dry rag. You should wind up with a surface that looks "chrome plated", i.e., tinned, but not heavily coated with solder. Re-apply flux & proceed with step 3.)
    3) Assemble joint.
    4) Heat the female fitting, applying the flame as far as possible from the end of the fitting where you will apply solder.
    5) Apply solder all around the joint -- it will wick into the fitting -- keeping the torch on the fitting, if necessary, as far away from the point of solder application as possible. Remember that the solder will flow towards the hot part of the work.
    6) While still hot, wipe around the joint with a dry rag to remove excess solder & examine for any gaps.
    Mike Hennessy
    Pittsburgh, PA
    1. mrfixitusa | Dec 08, 2006 08:44pm | #10
      Sometimes problems result when you cut out a section of the existing copper.For me, if I have enough room to spin the tubing cutter the full 360 degrees then I will have a nice clean cut.Where I have problems is when I'm in a tight spot and can't spin the tubing cutter the full 360.If I can't turn in the full 360 I'm better off using a hacksaw blade or maybe a dremel tool etc.^^^^^^
      S N A F U (Situation Normal: All Fouled Up)
      1. Renoun | Dec 11, 2006 09:03am | #11
        Go talk to the folks at your local plumbing supply house. There are now tubing cutters available for specific pipe sizes that only require around an inch of clearance.
        Actually you can just order one from from Amazon now.
        1. mrfixitusa | Dec 11, 2006 03:35pm | #12
          Cool - hey thanks a lot !^^^^^^
Mortar for Old Masonry
